Belt Alignment
Old May 1, 2010 | 10:27 PM
highlanderque's Avatar
highlanderque
Default Belt Alignment
I noticed that after installing my new 18" rear wheel that the belt is touching the side of the battery box. My bike is an '08 model w/ ABS and I'm using the stock rotor and pulley. Has anyone experienced a similar issue? Am I missing something?
Old May 1, 2010 | 11:34 PM
bigdoghd's Avatar
bigdoghd
I've seen this happen with exchanging rims and the inner hub is a different size.Take your side to side measurments and make sure its the same. Sound like you have an alignment issue or different hub size if I'm understanding you correctly
Old May 2, 2010 | 01:16 AM
highlanderque
BigDog,
These are aftermarket wheels. I will measure the inner hub in the morning.
Old May 2, 2010 | 05:09 AM
dog155's Avatar
dog155
Sounds like you need to shim the pulley out a tad.Lift the rear wheel off the floor and spin the wheel while sighting down the belt it should be obvious.
Old May 2, 2010 | 06:53 AM
sniper77's Avatar
sniper77
Spacer shims
http://shop.alljet.com/productdetail...catalogId=1570
Old May 2, 2010 | 08:16 AM
highlanderque
Thanks for the feedback.
boise nightrain
Jul 2, 2018 07:43 AM
Jon.alvarez4
May 26, 2017 09:49 AM
busterman2
EVO
Aug 17, 2011 02:17 PM
uzuzap
Nov 7, 2009 08:18 PM
Wally
Mar 22, 2008 12:40 AM
