Removing Stock A/C ,,Help
Old May 4, 2010 | 04:39 PM
GEORGEW's Avatar
GEORGEW
Default Removing Stock A/C ,,Help
On a 09 Street Glide do I have to loosen the gas tank to remove the stock Air/Cleaner?
Old May 4, 2010 | 04:45 PM
Scubamike's Avatar
Scubamike
No, I am guessing you are referring to the back black plate that is held on by I think two allen head screws but I forget the size. Use a 90 degree allen wrench and take your time it is very tight but you can get in there and remove those fasteners. Be careful not to scratch the tank with the allen wrench but I did mine and I know it can be removed without messing with the tank. Good Luck!
Old May 4, 2010 | 04:49 PM
pled55's Avatar
pled55
i didn't when i did my heavy breather .when removing the bracket on top of the throttle body i taped the side of the tank and any other areas thay may be scratched.just takes a little longer than removing or raising tank.just have patience
Old May 8, 2010 | 12:56 PM
GEORGEW's Avatar
GEORGEW
What size allen heads do I need ,,,and is there anything else I need to know?
Old May 8, 2010 | 01:51 PM
stanbo's Avatar
stanbo
6th Gear
I think 5/16.
milleda31
Jan 9, 2014 04:19 PM
BuzzL
Aug 1, 2012 04:56 AM
Tek74
Apr 3, 2011 11:57 AM
bucky68
Mar 26, 2009 09:26 PM
RODEO
Feb 14, 2009 09:48 PM
