oil
Old May 8, 2010 | 04:20 PM
pigeonblood's Avatar
pigeonblood
Stage III
Default oil
i have an '05 electric glide classic..wanted to verify that it is Ok to use amsoil 20w 50 in all three ...primary..transmission and engine?..then i read that ATF is also used...in all three also..lookn for some good advice
Old May 8, 2010 | 04:34 PM
Ronp42's Avatar
Ronp42
Account Retired
I don't know where you read it was ok to use ATF in all three holes??? That is a no no, never use ATF in anything but the primary. Amsoil 20W50 would be great for the Engine, but I would use A gear lube for the transmission. I use and like Redline Heavy with Shockproof in my transmission. Shifts very smooth and calms down the gear clunk some.
Old May 8, 2010 | 04:48 PM
dbinbc's Avatar
dbinbc
Yes, any good V-twin formulated 20W50 for the engine, preferably synthetic. That way it is designed to withstand the temperature changes. Go with Redline Shockproof in the tranny, can't go wrong there. Use a gear oil for the primary or even better, something made for the primary. If nothing else, go with Harley's Formula +, its made for that purpose. You don't want engine oil in there because it has different friction qualities. ATF is for automatic transmissions, an MTF for manual trannys would be better but still not right. Go with a top of the line GL5 like the Redline for your 5 speed. A GL4 would work but why not go with the best you can get.
Old May 8, 2010 | 06:11 PM
iclick's Avatar
iclick
Good grief, no! ATF is fine for the primary, but don't even think about it in the tranny, and the engine...where's my smelling sauce! Okay, I'm alright now, just got a bit light-headed.
Suggestions:
Engine -- Any good synthetic oil close to mfr. spec. Take your pick. It does not need to be MC-specific!
Tranny -- Gear oil. Many like Redline Shockproof Heavy.
Primary -- Almost anything: ATF and cheap fossil engine oil are probably the best choices. Anything over about $3/qt. is overkill, IMO, as the primary does not need a high-tech oil. In fact, too much lubricity is not good for proper clutch operation.
Lifeofchaos13
Sep 13, 2012 12:10 PM
steelerdude1
Jul 19, 2011 08:21 PM
cruzmisl
Aug 23, 2010 08:20 PM
fgunnr
Oil Archive (no new posts)
Oct 10, 2008 02:52 PM
hambone51
Feb 6, 2007 02:26 AM
