HD primary self adjusting tensioner question
Old May 29, 2010 | 12:14 PM
CroK's Avatar
CroK
Originally Posted by adedeluk
Put in gears like I did and never have to worry anymore.
Please, for us morons, would you post a pic of your primary WITH the chain removed and new gears installed?
Old May 29, 2010 | 12:19 PM
Tucson_Tim's Avatar
Tucson_Tim
Dumb question, since I'm at work and don't have my service manual:
Is the automatic primary drive chain tensioner a stock item on 08 Softails?
Old May 29, 2010 | 02:52 PM
tedcmiller (Cry Baby)'s Avatar
Most late model H-D touring bikes (at least 2007 and up) come with the H-D primary chain tensioner installed. In fact the port normally available for tension adjustment was eliminated on the primary chain cover on any bike that had the chain tensioner installed at the factory.
Old May 29, 2010 | 03:00 PM
I used to Hayden M6 tensioners on a couple of bikes with no problems. However, I did wonder why there were two springs, one inside the other. Then I realized that either spring would retain the pieces of the other spring if it broke. Without this safegaurd, a broken spring could get loose in the primary with potentially bad results.
Old May 31, 2010 | 01:06 AM
CroK's Avatar
CroK
Double springs used as a 'safeguard' incase one spring breaks...
Novel idea, even if it does show your mechanical expertise is built upon supposition alone...
Old May 31, 2010 | 03:24 AM
emwolb's Avatar
emwolb
i put the automatic primary tensioner in my 02 fxdl a few years ago, and it was an easy install. it worked great for me. next bike was an 07 streetbob, and now my 08 sg. after having three bikes with the auto tensioner, i feel it's a great improvement. it's just one less thing to worry about.
Old May 31, 2010 | 12:32 PM
CroK's Avatar
CroK
An '02, '07, now an '08...
If you've had the bikes only a few years each, how do you expect to have enough experience to be the judge of the effect parts have? Just sayin...
cajun1957a
Feb 7, 2019 07:03 PM
GalvTexGuy
2014-2024 Touring Models
15
Oct 23, 2017 07:08 AM
kpolak
Feb 28, 2010 06:49 PM
stevet82002
Apr 12, 2008 09:49 AM
Dandy Don
Aug 25, 2007 07:32 PM
