Torque wrench
Old May 10, 2010 | 02:02 PM
adlerx's Avatar
adlerx
I went to sears yesterday, their inch lb tq wrench is on sale for $79.95. Yikes! I went to Harbor Freight and got one for $20. If I was gonna use it a lot, would probably get the craftsman but figure I'll use it less than ten times in my lifetime, HF is fine...
Old May 10, 2010 | 02:30 PM
Retrop's Avatar
Retrop
I bought a Sears "beam" type 25 years ago to use in the shop. It has more than enough capacity for anything I have ever used it on, even axle bolts and lug nuts. Call me old fashioned but if I need to convert to inch pounds or foot pounds I simply divide or multiple by 12. Too simple? Maybe.
Old May 10, 2010 | 02:33 PM
cooper57M's Avatar
cooper57M
Craftsman is good enough for me.
Old May 10, 2010 | 02:41 PM
hoethree's Avatar
hoethree
Not a mechanic and have never used a torque wrench, could someone explain the proper procedure? I get it that you attach your socket or bit and proceed to "tighten" the target bolt or screw, but how do you "read' the torque wrench? Do you "set" it to some reading or do you tighten until you reach a certain setting?
Old May 10, 2010 | 03:14 PM
Glyder's Avatar
Glyder
I was told the Harbor Freight ones were junk and not get them as the accuracy was way off. Guess I shouldnt have listened.
Old May 10, 2010 | 03:29 PM
slhanks4's Avatar
slhanks4
Originally Posted by iclick
I've had these two Harbor-Freight wrenches for about 10 years and find them reliable and accurate. Tested them along with a $325 Snap-On and an old Torsen and the Harbor-Freight wrenches were the most accurate of the group by far. They also have a lifetime guarantee, and I know of no other torque wrench that has one. You can buy both for about $36.
HF 1/4"-drive in/lb wrench
HF 1/2"-drive ft/lb wrench
BTW, the in/lb wrench is on sale now at the lowest price I've ever seen it offered.
Sweet! I'm going to go grab one, I have a 3/8" and 1/2", both ft/lbs. Thanks for the tip.
Old May 10, 2010 | 06:54 PM
piasspj's Avatar
piasspj
The Harbor Freight ones go on sale for $10. (I think the 1/2 drive is on sale now). Look for coupons, get 20% off.
Old May 10, 2010 | 08:44 PM
SICKBAGGER's Avatar
SICKBAGGER
I have all 3 from HF 1/4" 3/8" and 1/2" drive clicker torque wrenches and I also had dads old craftsman beam type. I did have to take the 1/2" drive back and get it replaced it was not working right it clicked once then never again. I had heard mixed feeling about the HF torque wrenches but have checked them with other viable sources before using and mine are good and have a life time warranty! I got he 1/2" on sale for 9.99 and the other two for the 20% with the coupon just check them with a viable source before you use them and always readjust back to 0 everytime even if incrimenting up to the next torque level in a sequence is what I do. Most torque setting are a range I shoot for the middle and the wrenches say they have a .04% + or - accuracy.
Old May 10, 2010 | 10:06 PM
ev780's Avatar
ev780
How bout dog bone adapters? The only ones I can find are from Snap On I think, and are outrageous.
Old May 10, 2010 | 10:24 PM
SICKBAGGER's Avatar
SICKBAGGER
Made my own set took some old wrencehs and sockets cut one end off the wrenches and welded the sockets on making sure that the shaft drive of the socket was oreiented with the shaft of the wrench for squarness so 90 degrees could be found easily I found I have one that was a little off but by adjusting the torque wrench and puting the socket part on the wrench one way I can still acheive the 90 dgree portion.
