I have noticed that the torque specs range from a few inch lbs to several foot lbs. Is there one torque wrench you could recommend?
I have (2) of them from Sears. One is for foot lbs. and the other is for inch lbs. If you sign up for a Craftsman Club card you can get some decent deals. With Father's Day coming up you might want to wait and see if they will be on special. I don't know of any that will do both ? If you've never had a torque wrench before make sure that when you are done with either of them that you take the "load" off of them and put them back to zero. You don't want them sitting in your tool box set to whatever. It stresses out the mechanism inside. Anyway... you can't have too many tools and you'll really need these for your tool set... lol
Reason: content
The Sears kit is probably the best deal you'll find. Both wrenches in a small case. More than adequate for home use. Not likely that anyone makes a single device for both.
I've had these two Harbor-Freight wrenches for about 10 years and find them reliable and accurate. Tested them along with a $325 Snap-On and an old Torsen and the Harbor-Freight wrenches were the most accurate of the group by far. They also have a lifetime guarantee, and I know of no other torque wrench that has one. You can buy both for about $36.
