i have an 06 sg and i got apc3 and air filter setup from fuelmoto they sell a k&n high flow airfilter kit. few questions i have please
first the 2 hoses that connect to the 2 nipples on the bolts are no longer used i just want to make sure this is normal.
and also you reuse the stock air filter cover but since u dont use the stock backing plate do you take the gasket off from around the cover it seems like it will fall off if i do not.
and lastly the air filter cover since theres no more stock backing plate just kinda lays over the new filter assembly looks kinda weird to me that its not a closed setup i just want to make sure this is normal also.
