PCV Odor
Old May 13, 2010 | 10:23 PM
papifun's Avatar
papifun
Default PCV Odor
Friends that ride behind my scoot with their bikes complain that my exhaust has a heavy smell of unburned fuel.. i have 2 maps set up on my PCV with a switch for cooling and Cruising from FM. I am at times hard on the throttle having fun but also while i am cruising they smell the gas fumes... Does anyone else have this issue ? And it aint fumes from my butt either !!!
there is only some popping when the engine is cold and I rev to 4K RPM but once motor is warmed up no more popping and bike runs fine. Is this odour normal due to adding more fuel to keep bike cooler ?
Old May 13, 2010 | 10:44 PM
WI Bob's Avatar
WI Bob
I have noticed when I run my richer maps there is a smell of gas in the garage after I park the bike. It doesn't take much change to make the smell go away. Just .3-.5 on the air fuel ratio.
Might you have a dyno handy where they will let you on to do a run for the numbers and test the air fuel mix in the exhaust?
Fresh plugs might make it happier. Just guessing.
Old May 13, 2010 | 11:07 PM
RAP's Avatar
RAP
4 Grand on a cold engine?
Old May 14, 2010 | 12:38 AM
BBStacker's Avatar
BBStacker
Running rich = more fuel.
widerglider2012
Jun 12, 2012 07:39 PM
frenchbiker
Jun 4, 2012 08:16 PM
hinerj
Mar 2, 2012 01:32 PM
kyleplusitunes
Dec 27, 2011 04:57 PM
TooEasy
Mar 27, 2011 05:09 PM
