Since the Heritage bars are not drilled for internal wiring, all i have to do is slip off controls on old bars and slip em back on the new ones right. No cable adjustment or anything.
Sounds too easy, am I missing something?
I went from stock to Heritage on my 02 RKC.
Everything worked. The wiring was tight but it worked.
There are 4 little plastic wire clips that you may need if you can't re-use
the old ones. Zip ties will work but the clips look nicer.
