01 RKC Header Question
Old May 19, 2010 | 07:45 AM
TheDon81's Avatar
TheDon81
I got mine from Denniskirk, this was last year and it looks like they have gone up in price a little, I am sure you can find them on ebay too. Also look at eastern performance or try and find a Forum sponsor (i.e. Dr. V-Twin)that sells them.
Old May 19, 2010 | 04:53 PM
cpotts454's Avatar
cpotts454
Thanks for the info TheDon. I found a source for $330 new and shipped. I think the V&N is the way to go. Then I can change out slip on mufflers as needed. Did you see any performance loss when changing from stock? Ive read you loose a little torque. Although I dont really understand why. If you are using a baffled exhaust you are still getting back pressure... The only thing you are loosing going to a true dual is the equalized pressure between front and rear cylinders.
Old May 20, 2010 | 07:03 AM
TheDon81's Avatar
TheDon81
Your right you still have backpressure but that is not what is helping you, the stock exhaust has the same scavaging effect as a 2 into 1, personally I didn't notice much if any difference, but I spend most my time in the 2500-3000 RPM range (lots of Highway) where the duals will outperform the 2 into 1.
SBates08
Nov 15, 2013 02:52 PM
hivoltg
Apr 19, 2010 01:20 AM
Magos
Mar 17, 2009 08:18 AM
LANZANTE13
Feb 25, 2008 09:48 PM
sligarn5
Apr 22, 2007 09:25 PM
