True Duals Header
Old Nov 12, 2013 | 06:46 AM
SBates08's Avatar
SBates08
Default True Duals Header
Trying to find true duals with both 18mm and 12mm O2 bungs. Have been searching diligently for several weeks now and have came across only 2...Dragos and Freedom Performance. Are there any other choices out there? Nothing wrong with either of these, just trying to cover all options. Wanting a header with the capabilities to run AutoTune with PV.
And to clarify, I Do Not want an X-Pipe or a header with a Crossover nor do I want Rinehart. Looking for True Dual headers that will accept most all slipons.
Thanks for your help.
Old Nov 12, 2013 | 07:54 AM
Northbound Southerner's Avatar
I think Bassani makes a set that accepts both. I'm looking for the same thing right now...
Webo's Avatar
Webo
I believe the MGS duals head pipes come with both size O2 ports and they are a true dual system. http://www.mgscustombikes.com/mgs-exhaust/true-duals/
Old Nov 12, 2013 | 10:08 AM
SBates08's Avatar
SBates08
I looked at the Bassani. Don't like the looks of the Power Curve and I really don't want the Classic True Dual look either. I've found the Freedom Performance for $359 but can't find many reviews on it.
Thanks Webo but I really don't like the Classic True Dual look. Plus I'm not sure if the MGS header will accept 1 3/4" muffler.
Old Nov 12, 2013 | 10:37 AM
gmc's Avatar
gmc
Yes they do! They are stepped up headers that give you the backpressure needed to get better torque than most.
Old Nov 12, 2013 | 11:02 AM
SBates08's Avatar
SBates08
But they are the "Classic True Dual" design and I don't care for that look. I like the look of the dresser duals but from what I'm seeing my options are limited.
Old Nov 12, 2013 | 11:17 AM
rastas's Avatar
rastas
Supertrapp do a true dual system. But I am unsure if they have both 12-18mm bungs you are after?
Old Nov 12, 2013 | 11:20 AM
SBates08's Avatar
SBates08
Thanks Rastas ill give them a look.
Old Nov 12, 2013 | 11:23 AM
user 8373900's Avatar
user 8373900
Get what you want and have the ones welded on they don't have? the AT bungs need to be close to the head as possible, so on true duals the 12's are down low so you can add the 18's up top. I have not heard of a bushing to neck down to 12 but it would be cool.
Mark
Old Nov 12, 2013 | 11:58 AM
gmc's Avatar
gmc
They have both styles. Maybe give them a call.
http://mgscustombikes.gostorego.com/...oss-under.html
