I have a 01 Road King and just installed them. A much better ride than the old air but I'm noticing a little vibration at higher speeds (60-70). Does anyone know the correct torque for the bolts? The instruction that came with the scocks are not clear. They require that the shock mounts have a minimum clearance of .02" to insure the mounts are not binding and show a pic of a .02" clearance between the mount and the and the flat washer. Don't know how you can do this as the bolt also has a lock washer. How tight do the bolts have to be?
