Afr
Old May 22, 2010 | 05:53 PM
oscarg's Avatar
oscarg
Default AFR and PCV and Autotune
The AFR # I take it stands for air fuel ratio. Is the number the amount
of air to one part fuel ???
Old May 22, 2010 | 06:14 PM
bjpharmd's Avatar
bjpharmd
yup. mass of air to fuel.
Old May 22, 2010 | 06:59 PM
oscarg's Avatar
oscarg
So the larger the number the leaner it is? So what numbers are considered best for mileage or power or cooling and still be safe for the engine
Old May 22, 2010 | 07:16 PM
bjpharmd's Avatar
bjpharmd
warning... I'm no gear head... ok.. I guess that would depend on different variables such as whether or not you are running an oil cooler for one thing. Other than that it would depend on engine rpm and throttle postition. When you twist the throttle to get goin you would want a lower AFR (like 13.5 or so) but if you're just scootin along at highway speed you could be up around 14.4 or 14.6. The higher the AFR, the better the mileage, the hotter the bike. The lower the AFR, dimished MPG, but the bike runs cooler. Take a look at a post discussing The Power Commander V. There will probably be a post that shows an AFR table. It'll show different AFR's at different Throttle Positions vs. Different engine RPM's. You can manipulate (increase) the AFR's values to give you better MPG or you can decrease the AFR to give you better cooling or more power. My take on it anyway.
Old May 22, 2010 | 08:00 PM
oscarg's Avatar
oscarg
Thanks I have seen the AFR charts but know explaination
of what the numbers mean. I need a simple understanding
of what and why I am changing and how it effects the engine
Diverrick
Aug 15, 2016 05:19 AM
erbssr
Jun 28, 2014 03:34 AM
09StreetGlider
Feb 17, 2009 10:58 PM
lecomte38
Exhaust System Topics
May 27, 2008 04:55 PM
Babe
Aug 16, 2007 05:37 AM
