Speedomoter Wrong?
Old Jun 14, 2010 | 03:38 AM
sgdiesel's Avatar
sgdiesel
My understanding has always been that speedo's are intentionally set optimistically by circa 5% and this is a legal requirement so I am intrigued to see some experiences with cars that have matching speeds.
That said, I would not share a blinding faith in what GPS reports either, and suspect that the truth lies somewhere between the 2. In particular, given the way GPS works, it takes little or no account of elevation change so I expect it would be more accurate on straight, flat roads that hilly sections.
I have never noticed a significant difference in Odo reading vs SatNav, but again I would be more inclined to trust the odo
Old Jun 14, 2010 | 04:59 AM
NoKenDo's Avatar
NoKenDo
The speedo is not the only inaccurate gauge on your bike.
Just have a look at the air temp or the gas gauge.
Just saying.
Old Jun 14, 2010 | 05:57 AM
2WheelGlider's Avatar
2WheelGlider
Every one I have ever had has been off by about 5%. My metrics from the old days were off alot more than that.
Old Jun 14, 2010 | 06:57 AM
audettd's Avatar
audettd
Its very common for the GPS to show a difference....its not suppose to be 100% accurate (check the accuracy of the distance shown, Mine usually says something like 10' or 15')...that means its not 100%. I wouldn't expect the MPH to be any different.
Old Jun 14, 2010 | 12:41 PM
tedcmiller (Cry Baby)'s Avatar
audettd, 15 feet out of 5280 is less than 0.3 % I think the GPS is considerably more accurate than the H-D speedometer.
Old Jun 14, 2010 | 12:50 PM
SlowRain's Avatar
SlowRain
The GPS showing a few mph slower is normal...does it on my bike. I used to use another Garmin in my cage and it did the exact same thing....a 2 mph difference slower on the GPS on both the cage and the car.
Had a friend of mine who is an LEO clock me with a radar and the speedo on the bike is dead on. Also ran the distance between mile posts at 60 mph and it took 1 minute on the stopwatch. I am thinking the speedo on the bike is accurate enough.
Old Jun 14, 2010 | 02:07 PM
bdp's Avatar
bdp
Talking
Originally Posted by BBStacker
Once again a GPS doesn't (obviously) read speed the same way as your speedo. You get speed from a GPS by looking at where you are at one time, and
where you are at another, and dividing distance by time. You speedo is based on revolutions of your wheel. Put simply.
Sorry, must have missed the 1st time you wrote it,
Old Jun 14, 2010 | 06:12 PM
Sunrider00's Avatar
Sunrider00
Same exact thing here. My Zumo reads 70 and the speedo reads 73.
Old Jun 14, 2010 | 06:15 PM
07FLHT's Avatar
07FLHT
Originally Posted by deadhead111469
Mines off by -4 mph
+1
Old Jun 14, 2010 | 06:43 PM
davessworks's Avatar
davessworks
A few thoughts: Speed on your bike's gauge is based on signals from the vehicle's speed sensor which is located on the transmission (unless you have an older bike - my Evo had a speedometer cable attached to the front wheel). Regardless of cable drive or transmission sensor the assumption is that the tires have a certain circumference and therefore each rotation (be it calculated on drive ratio or simply one wheel rotation) results in a predetermined distance traveled. Realistically this can only be "accurate" when the tire is exactly the right diameter and there are variables that affect the tire's circumference such as make, model, inflation and wear.
GPS, on the other hand, measures the distance traveled in a prescribed time. Measurement of time is relatively accurate so the inaccuracies in GPS speed are, as has already been stated, due to GPS distance inaccuracies. At high speeds the GPS distance accuracy becomes less of an issue so if you want to compare your speedometer against GPS do it at higher speeds, not at 20mph.
