Installing Jackpot Headpipe
Old May 24, 2010 | 07:41 PM
red.heritage's Avatar
red.heritage
Default Installing Jackpot Headpipe
Today I ordered exhaust, a/c PCV, and headpipe from Fuelmoto. I forgot to ask Jamie about the exhaust gaskets for the headpipe. Does anyone who has already installed the headpipe remember what type gasket is needed?
Thanks a lot,
Richard
Old May 24, 2010 | 08:18 PM
RK14SGS's Avatar
RK14SGS
My experience- copper rings are best. Stock replacement is fine as well. Also, once I had to re-use the factory gasket that was already there and had no issues.
Just my $0.02...
Old May 24, 2010 | 10:14 PM
Tombo359's Avatar
Tombo359
My bike was new with only 600 miles on it and I just reused the original ones. I did have to replace the gasket in the crossover pipe and use a tailpipe expander to get it to fit over the new headpipe. It may be my imagination but the headpipe and jackpot slip ons seemed to make a big difference in torque on my Limited 103.
Old May 25, 2010 | 01:18 AM
cafedante's Avatar
cafedante
I ordered the same header and was told by Fuelmoto to use the same gaskets from the stock pipe.
However, just to be on the safe side I put and order in for the 17048-98 HARLEY DAVIDSON Screamin' Eagle® Performance Exhaust Gasket Kit.
Old May 25, 2010 | 06:07 AM
Spur56's Avatar
Spur56
Gaskets are cheap, get new ones. PITA to have to remove because of a leak. The stock ones are fine.
Old May 27, 2010 | 01:02 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
The Jackpot 2/1/2 head pipe is designed to be used with stock tapered exhaust gaskets and each pipe is built to exact specs and tested in a CNC fixture, if you use the SE or other flat style gaskets the fitment will be changed from our specs as the pipe will essentially be moved .200 toward the motor. The billet collars on our pipe are closely matched to the exhaust port and offer a perfect seal with the tapered gaskets. I recommend inspecting the factory gaskets including the gasket on the crossover pipe and replacing them if needed, we do commonly reuse them here as long as everything is carefully disassembled and they look good.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old May 27, 2010 | 01:16 PM
Avalanche_Mutt's Avatar
Avalanche_Mutt
torque is increased for sure way cooler on the leg too!!
Old May 27, 2010 | 01:32 PM
WI Bob's Avatar
WI Bob
Listen to Jamie here.
I used the SE gaskets and it made things a bit tight around the motor for the front down pipe. The stock gaskets would have gave the proper clearance.
Bob
Old May 27, 2010 | 11:26 PM
NoCoLoco's Avatar
NoCoLoco
I've never been a big fan of re-using gaskets of any kind. I recommend buying new OEM gaskets for the Jackpot headers.
je3169
Jun 9, 2015 12:44 PM
TKanaley
May 29, 2012 12:29 PM
vduzin12
Oct 17, 2011 11:31 AM
ronbeejer
Dec 25, 2010 09:00 PM
TickTock
Nov 6, 2010 07:46 AM
