Exhaust Gaskets
Old Nov 5, 2010 | 05:08 PM
TickTock's Avatar
TickTock
Default Exhaust Gaskets
Question on the stock gaskets. There is a thin side and a thicker side. Which side goes towards the engine and which side goes towards the exhaust pipe?
Old Nov 5, 2010 | 05:10 PM
SoonerSoftail's Avatar
SoonerSoftail
Thick side goes in. It tapers toward the outside.
Old Nov 5, 2010 | 07:27 PM
hd_rolling's Avatar
hd_rolling
If your installing an aftermarket head pipe that is noy tapered and has the square flat end you should use the screaming eagle square gaskets. The stock headpipe is tapered and if you set the stock crush style gaskets up to the head pipe you will see how it should fit together. If you try to use the stock crush style gaskets with an after market headpipe that is square and over tighten the head pipe while installing you could crush the stock gaskets down and could block some of the exhaust flow which might hinder performance. JFYO
Old Nov 5, 2010 | 11:02 PM
TCMAN's Avatar
TCMAN
Yes, thick side in, James Gaskets also makes a square style gasket, your local indy probably stocks them.
Old Nov 6, 2010 | 07:29 AM
TickTock's Avatar
TickTock
I am installing the Jackpot HeadPipe from Fuel Moto and thought since I was in there I would just go ahead and put in new gaskets. I believe you would call these square, but Jamie has indicated that they usually don't replace the gaskets. I intended on torquing them in to the specifications indicated in the manual.
Old Nov 6, 2010 | 07:32 AM
1flhtk4me's Avatar
1flhtk4me
I used the stock gaskets with 1,400 miles when I installed the FM 2-1-2 head pipe.No problems.
Old Nov 6, 2010 | 07:41 AM
TickTock's Avatar
TickTock
Which set up did you buy and which tuner did you use? I purchased the headpipe and dyno tuned muffler combo and Arlen Ness stage 1 Big Sucker. I am going to tune with the TTS - got an appointment with Doc all set up.
Old Nov 6, 2010 | 07:46 AM
1flhtk4me's Avatar
1flhtk4me
I bought the 2-1-2,Jackpot Dyno Tuned's,PC5 and the K&N.
I like the sound of the Jackpots.Not loud at idle or cruising at freeway speeds(can hear radio)but they make noise when on the gas.
d24112
Nov 27, 2016 08:31 PM
canyonking
Dec 6, 2015 09:01 PM
TKanaley
May 29, 2012 12:29 PM
jm04
May 31, 2011 03:09 AM
RidemyEVO
Exhaust System Topics
Mar 9, 2010 10:02 AM
