58mm TB
Old May 24, 2010 | 09:05 PM
RickyB's Avatar
RickyB
Default 58mm TB
Im having a 103" built port and polished heads buy wolfgang grasser and wolf is suggesting a 58mm TB is this to big for a 103?
Thanks.
Old May 24, 2010 | 09:28 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
58mm is too big unless your planning on racing the engine at high rpms often. Its like putting a toilet bowl on the 103 engine. Another thing to keep in mind is what intake port size is he taking the heads too? Are you going to run high compression pistons? Keeping the stock intake port size on the head, the 58mm would be too big.
HPI does great work on stock 50mm TBW induction modules for much less then the cost of the 58mm. I had HPI do my 50mm to a 54mm for my Tman stage 2 touring heads for my 117". Took 2 weeks for them to work my TBW and send it back to me
Old May 24, 2010 | 09:29 PM
Biggzed's Avatar
Biggzed
Thanks.
If he's suggesting it there is probably a good reason. He knows what works with his stuff. If you don't want to spring for the new TB, talk to him and agree on what will be expected of the build after you modified his formula. That way there is no finger pointing to be done.
Zach
Old May 25, 2010 | 12:02 AM
qtrracer's Avatar
qtrracer
I have one on my 103" and the sizing theory that was used in choosing carbs has no usage in choosing TB's. If you trust Wolf to do your heads why do you not trust his recommendation on TB's?
Old May 25, 2010 | 08:23 AM
'05Train's Avatar
'05Train
58mm on my 103 as well, it runs like a raped ape.
Old May 25, 2010 | 08:34 AM
PhilM's Avatar
PhilM
If he set your heads up with 1.800" intake ports, the stock TB will never seal properly.
Initially, the S/E 58 was the only option. Now that HPI is working stock TB's & using whatever port size you actually need (1.67, 1.710, 1.800), there is a better alternative.
I been advised that the HPI 54 (modified stock) actually out flows the S/E58.....
Having said all that, if ya paid the guy to do your heads, you should probably listen to him regardinghow to make his stuff work.
Old May 25, 2010 | 08:22 PM
RickyB's Avatar
RickyB
He said the stock 50mm will work but the 58mm will give me a little more power.
FXDF619
Jan 16, 2015 02:06 PM
HD Pilot
Exhaust System Topics
Jul 5, 2013 11:57 AM
128auto
Jun 22, 2013 01:50 PM
N-gin
Sep 27, 2010 06:37 AM
tschmidtgal
Aug 16, 2010 03:27 PM
