need help wiring for apes!!!
Old May 25, 2010 | 11:10 AM
lock55's Avatar
lock55
Default need help wiring for apes!!!
I am installing 13 inch apes on my bike. I bought a kit from Hill Country. I am having trouble figuring out the wire extending process. Any help would be greatly appreciated.
TBW – The plug coming from the handlebars is a male. HCC kits provide extension wires with plug ends attached (male/female). How do you remove the male plug ends for the Molex plugs? Do you need to take the plug apart, if so what is the procedure for this? I read the section in the owner’s manual on connection plugs and still can’t figure it out.
Thanks in advance for any help you can give me.
Old May 25, 2010 | 12:27 PM
lock55's Avatar
lock55
I figured it out, just have to read the manual a little slower....
Old May 25, 2010 | 12:33 PM
twistr's Avatar
twistr
Yup...you gotta take the plugs apart...fairly simple...plug extension into the existing wires and use the provided shrink wrap over the wire connection..install the plugs on the new extended wires..make sure the proper wire go back into the same spot it was on the plug.
Old May 26, 2010 | 01:32 PM
HDUltra08's Avatar
HDUltra08
Stage III
You'll find a better install if you remove the male connectors from the harness and the female from the extensions and soldier the wires.
Old May 26, 2010 | 01:36 PM
Jags93's Avatar
Jags93
Plus more room for snaking the wires
Old May 26, 2010 | 02:08 PM
HDSAE60's Avatar
HDSAE60
you can't pull that plug through the bar soldering all pins even the factory ones will prevent failure down the road
Rhino-1
2014-2024 Touring Models
Jul 7, 2016 06:10 PM
09FLHT
Nov 25, 2012 09:15 AM
landslide03
Oct 5, 2012 06:51 AM
nashspu
Sep 6, 2012 12:38 PM
jabroni73
May 17, 2010 06:19 PM
