HD cb junk ?
Old May 26, 2010 | 07:32 PM
cowboy Harry's Avatar
cowboy Harry
Default HD cb junk ?
Are all the c b radios on the Ultras junk??????????? Bout all I hear on mine is electronic engine noise when recieving transmistions. It is on the 2010 Ultra. Do they all suck or is it just mine ????????????????????
Old May 26, 2010 | 07:47 PM
LynP408's Avatar
LynP408
I have an 09 Ultra SE -- CB is junk. Have yet for someone to acknowledge my attempts, even riding beside big trucks. Just doesn't work properly. Can adjust squelch and volume and using HD headset for half helmet. I now use the CB as much as I do the navigator...not at all.
Old May 26, 2010 | 07:49 PM
laduckslayer's Avatar
laduckslayer
I ride with a group and they just chat it up on the cb. I have not heard $hit yet. I quit trying.
Old May 26, 2010 | 08:03 PM
BkrDude001's Avatar
BkrDude001
I've not had any issues with my '08. I am told that it sounds good and I hear with it good.
Old May 26, 2010 | 08:18 PM
Greyboat's Avatar
Greyboat
I have an 08, and mine works fine given the ground plane of a bike or lack there of.
I ride with a buddy that also has an 08 and an 05 before that, both seemed to work well. We talk to truckers but only have a range of about a mile.
Now, if you talk to any good CB shop they can tell you about properly tuning your antenna using an SWR meter and that you can improve the range a bit by using a 1" wide ground strap attached to the metal plate in the tour pak and the bike frame. I only tried the SWR tuning. Talk to the experts, not the dealer
Old May 26, 2010 | 08:25 PM
shortride's Avatar
shortride
I don't use the CB on my '09 Ultra often but it seems to work find when I do use it. I won't be using it at all after taking the tour-pak off.
Old May 26, 2010 | 08:43 PM
bmaier's Avatar
bmaier
Great for group rides. Whenever we have a chapter ride all of us on Ultras share stories on our CBs.
bigdoghd's Avatar
bigdoghd
I do know that the SWR reading place a big factor in how well the cb will work. You can by one at radio shack and check it for yourself. If I remember correctly you want it as close to a 1:1 ratio on low channel, mid channel and high. That's done by a adjustment to the antenna usually
Old May 26, 2010 | 08:45 PM
Notgrownup's Avatar
Notgrownup
I ride with 3 Goldwingers and one with a 08 ultra and i have a 07 with a J&M ...HD sounds a bit canny ...GW's very clear...they say i sound a bit scratchy...Oh yeah..SWr'S vERY IMPORTANT ...have it checked by a CB shop... mine was way off and i put a K20 antenna...i use it a lot.
Old May 26, 2010 | 08:50 PM
Biker Oma's Avatar
Biker Oma
Ours works fine on our '09 Ultra. Because we tour alone, its not a big deal but for 2 years running we have been involved in a long weekend rally and it was very helpful to have the communication to co-ordinate large groups of bikes.
