CB Removal ???
Old May 28, 2010 | 12:32 PM
jgcable's Avatar
jgcable
Default CB Removal ???
I am thinking about completely removing the CB from my 1990 FLHTCU. I am never going to use it. Has anybody ever done it? Is there a cover or filler dash plate available once its removed? It will look horrible with it removed unless there is some sort of dash plate available.
I think I am also going to remove the large factory rear antenna and replace it with a shorty or maybe remove it completely and install one of those antenna's that mounts inside the fairing.
Old May 28, 2010 | 01:19 PM
Ultra89Rider's Avatar
Ultra89Rider
Yes. Just unplug the CB and the Control Panel from the dash. Unbolt both and remove.
The dash has an insert to cover the hole that is left on the dash. Part numbers are as follows:
60973-90 Insert, console panel (black) FLHTC
60974-90 Insert, console panel (brown) FLHTC
Old May 28, 2010 | 03:17 PM
jgcable's Avatar
jgcable
You are the man. Thanks! JG
Old May 28, 2010 | 10:24 PM
Ultra89Rider
Also if you remove the antenna from the Tour Pak, you can leave the stud in place. Just cover it with a rubber vacuum cap. They come in various colors. Black is the color of the Ultra Rear Lights on the Tour Pak. I put the antenna inside my fairing. It cleaned up the Tour Pak a lot. Then I just rolled up the antenna line that went into the Tour Pak and tucked it under the side cover.
Punisher2000
Jun 10, 2017 05:19 PM
slowrollin
Apr 4, 2016 09:33 AM
rhinoevans
May 24, 2010 04:12 PM
Biff_H
May 18, 2010 09:48 PM
Badbagger
Mar 24, 2009 09:57 PM
