Arc Amp Problem
Old May 29, 2010 | 05:45 PM
MassHD's Avatar
MassHD
Default Arc Amp Problem
Any idea's would help. The amp seems to be cutting out. I get 4 flashs on the power button. Everything was fine and last weekend I hit a bump in the road . Since then I've been having this problem.
Old May 29, 2010 | 06:05 PM
vickers1's Avatar
vickers1
Sounds like you may have shorted a speaker wire. The amps have built in protection that shut down the audio in case a speaker wire gets grounded. Check your wires all the way from the amp to the speakers. Chances are one has gotten nicked and grounded. Otherwise you have an amp or a speaker going bad.
Old May 29, 2010 | 07:56 PM
2of2's Avatar
2of2
Check your ground wire. Make sure you have a good ground to the frame. I used the bolt for the crash bar.
Old May 29, 2010 | 07:59 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
and remove all paint from the area u use for the ground.
Old May 29, 2010 | 11:17 PM
MassHD's Avatar
MassHD
The winner is a bad speaker. Man I've only had the arc 6.5" for a year. Well I'll have to ride with one speaker until I figure out what to do next.
Old May 30, 2010 | 09:54 AM
rjmac53's Avatar
rjmac53
keep us posted...
WVFLHX
Audio Systems
31
Mar 23, 2025 07:36 PM
Biggzed
Audio Systems
Jan 11, 2019 10:25 AM
racenut.pp@gmail.com
Audio Systems
Apr 4, 2017 11:07 PM
Harleypingman
Audio Systems
131
Jun 14, 2016 07:03 AM
hynsonx
Aug 31, 2013 09:43 AM
