LED Lights for Bike
Old Feb 27, 2011 | 01:08 PM
  #31
Heatwave's Avatar
Heatwave
Member
Originally Posted by Stang951
Heat you have the part number or a link to what you had to install? I want to get rid of the annoying delay also.
Seems like the Badlands unit is a LE though ....kinda irritating.
I assume you're using the Badlands Illuminator module with your LED turn signals (all 4 corners) and that you also have an LED Tailight (I used the BAL-3S).
If you have the same combination as I do with the fairing LED bar, the LE in the Illuminator module (ILL-01-A) just isn't enough to compensate for all these LEDs. But the fix is very simple to get your fairing LED light bar flashers to work properly. Essentially, Badlands took a regular LE and swapped the plugs out to fit my SE Ultra. It was then plugged in-line BEFORE the Illuminator. That was all I needed to do and the front signals and fairing LED bar worked perfectly. No issues at all with turn signals, light bar, tailight or HD security system. 4-way flashers also function properly for as long as I want to run them (no heat issue).
I believe Badlands has new modules they have released based on some of the experimenting they did with me. http://www.badlandsmotorcycleproduct...cts/BETCSM.htm
My recommendation is to call Dan at the Badlands #. Explain your exact lighting configuration and the issue you're having and they will be able to recommended the right module setup for you. (your combination might be different then mine since your bike is a 2005 and mine is a 2010.)
Old Feb 27, 2011 | 01:30 PM
  #32
Stang951's Avatar
Stang951
I believe it is an Illuminator (been a while since I installed it) Custom Dynamics turns front and rear, Custom Dynamics brake light, HD led windshield bar and HD LEd headlight.
I will try to call Dan this week. Not sure if they will send me a fix or if I will have to pay extra since it has been a while.
edvelez24
Mar 17, 2013 03:37 PM
Biker90
Mar 14, 2013 01:46 PM
Mr. Wizard
Oct 9, 2009 03:48 PM
rsofa
Mar 20, 2008 12:37 PM
2005UltraNC
Nov 22, 2006 12:37 PM
