How to remove left side grip?
Old Jun 4, 2010 | 06:27 AM
  #31
todd-67's Avatar
todd-67
Originally Posted by pettifogger1
Sent an email to Avon and received this response this morning. Avon uses a glue impregnated paper that is wrapped around the bar and then wetted so this won't work with other grips.
"Yes, you can go to your local pharmacy and buy a syringe and then squirt warm water under/into the grip to reactivate the adhesive, then gently twist the grip and you will hear the tape give and then you can slide the grip off. You will need another piece of tape to reinstall grip."
This is what I do only I use either naphtha or WD40 in the syringe. I used to do this on golf club grips as well.
Old Jun 4, 2010 | 11:04 AM
  #32
grumpy old biker's Avatar
grumpy old biker
Originally Posted by ashmarc
Not a true statement…….I know for a FACT, b/c my stock left grip was not glued when I swapped them out.
Grips on my shovel, evo, twin cam, and wifes sportster were all glued on. Maybe the plant missed yours.
Old Jun 4, 2010 | 12:45 PM
  #33
PistonPuller's Avatar
PistonPuller
True statement. All factory grips from production should be glued on. If they weren't then the factory missed it, or someone already swapped them out
Old Jun 4, 2010 | 12:53 PM
  #34
DrPlastic's Avatar
DrPlastic
No not true. TOURING models are kept on with a flange that fits up inside the switch housings. There is a flange with a notch that when trapped between the switch housings will not let the grip rotate due to the notch in the flange. Even my service manual states that the grip is installed this way. It makes NO REFERENCE TO GLUE!
Old Jun 4, 2010 | 12:58 PM
  #35
PistonPuller
My TOURING model was glued from the factory
Old Jun 4, 2010 | 01:19 PM
  #36
ashmarc's Avatar
ashmarc
Again, not true……
No need for a pissing match fellas….I am the original owner…..changed my grips twice now.
DrPlastic said it correctly, mine and I would assume most (obviously not all) touring models have no use for glue of any kind as the grips have "collars" on them that get wrapped over by the switch housings.
They cannot rotate or slide off.
Not a big deal, didn't mean to start any arguments.
Ride on boys!!
Old Jun 4, 2010 | 01:29 PM
  #37
PistonPuller
Again, not true……
Ride on boys!!
True there is no use for glue, but the statement I am agreeing with is MOST (with the exception of yours) come from the factory with the left grip glued on. I have swapped more than a few sets of grips. 3 sets were touring models and ALL of them had been glued from the factory. Again I am not saying they have to be glued on, just that the factory is suppose to glue them
Old Jun 4, 2010 | 02:02 PM
  #38
ashmarc's Avatar
ashmarc
Copy that Bennie…….c'mon now, snuggle up for a hug.
Old Jun 4, 2010 | 02:58 PM
  #39
PistonPuller
Old Oct 9, 2010 | 02:07 AM
  #40
Galvatron's Avatar
Galvatron
Here's what works to remove the factory left grip.
Give it a few twists to loosen the edge. Then poke an air nozel down the grip and blast, work it aroind the grip. Now grab some WD-40 eith a tube nizel on it, set the bars upright so the grip is on the bottom, poke the WD nozel under the edge of the grip. Give it a few light twists to let it soak in. No shout and throw your back into one giant twist and the grip should slide right off. Easy!
