2002 Electra Glide Help
Old May 31, 2010 | 02:32 PM
13point's Avatar
13point
1st Gear
Default 2002 Electra Glide Help
2002 Electra Glide, coming home last night engine light came on, lights dim and the rpms would not lower. I look at volts and it showed it was charging, can you help me trouble shoot this problem. I was thinking altranator, regulator or maybe even the battery. The battery is 4 years old and I take it out every winter but do not use a battery tender.
Old May 31, 2010 | 02:57 PM
dawg's Avatar
dawg
I'd start there. Bring the battery to dealer and they'll charge overnight and then put on the Midtronics battery tester. That will tell if the battery is good or shot. If not good, replace. You can also test the battery right in the bike if you have a multimeter and you can test the rest of the charging system as well.
Old May 31, 2010 | 03:21 PM
BLKBAGGER's Avatar
BLKBAGGER
Double check your connections before anything.
Old May 31, 2010 | 04:24 PM
13point's Avatar
13point
1st Gear
Thanks, I'll try the battery and check with multi-meter.
walkerinin
Nov 21, 2016 09:08 AM
whitlow
Oct 13, 2016 06:38 PM
whitlow
Electrical/Lighting/Alarm
Oct 12, 2016 07:06 PM
brentswth20
EVO
16
Dec 20, 2014 11:16 AM
RealDealHog
Jul 18, 2006 02:46 PM
