broken shifter
Old May 31, 2010 | 09:11 PM
VINNIE JAMES's Avatar
VINNIE JAMES
Default broken shifter
went to down shift and the toe shifter went down to the floor board. it lifts back up to the stock position but wont stay. tried to tighten the bolt and it wont turn? the heal shifter is fine. unbolted it and it came right off. can not get the toe shifter off.
anyone have this problem? any sugestions? thanks, vinnie
Old May 31, 2010 | 09:37 PM
Dionicio's Avatar
Dionicio
After taking the bolt out of the toe shiter, try to spread the shifter open with a large flat tipped screwdriver. Should come off easily.
Old May 31, 2010 | 09:46 PM
VINNIE JAMES
can not turn the bolt in the toe shifter? it wont move either way? also not sure if the shifter is striped or the shaft???? i really not sure what happened? its been fine. i ride every day that i can
Old May 31, 2010 | 09:59 PM
Dionicio's Avatar
Dionicio
Just an idea, the bolt may be jammed against the splines on the shaft. Try wiggling it (shifter) back and forth to see if it comes loose so You can take the bolt out
Old May 31, 2010 | 10:00 PM
jamesw's Avatar
jamesw
The shifter is much softer that the shaft, so it should strip first. Are you using a good allen key socket in a ratchet? Just an allen key by hand might be hard. I would suggest removing the bolt, then running a tap thru the shifter, then a new allen in stainless with a little blue loctite.
Old Jun 1, 2010 | 03:58 AM
paguy's Avatar
paguy
Never seize. Put on bolt, tighten, then check shifter is at right height, then tighten real good. The never seize allows the bolt to seat snugg.
Old Jun 1, 2010 | 04:54 AM
Eddy G's Avatar
Eddy G
I've seen the shifters loosen up just enough to vibrate and wear the spindle down to a nub. It can happen over a short period of time or even pretty quickly.
The vibration may have damaged the threads in the bolt, nut, the spline, the shifter or any where in between. Its hard to say without seeing it.
Most importantly is the spline. The rest you can fix in garage easy enough. Without seeing in
I'd suggest cutting the shifter bolt.
Use a dremel tool with a cutting wheel. It will fit between the split in the shifter.
Spread the shifter with a large flat head screwdriver or wide blade cold chisel.
As long as the spline is OK, go and get yourself a new shifter. Clean and lubricate everything. I use stainless hardware (from any true value hardware store) and use a lock washer.
Good Luck
jamess71
Jul 15, 2016 10:08 AM
beary
Jul 21, 2014 12:50 PM
PFR-Captain
Jun 5, 2014 02:27 PM
speedkills
Mar 2, 2010 08:20 PM
evil_monster
Mar 4, 2009 08:53 PM
