SE 255 cams
Old Jun 14, 2010 | 12:09 AM
  #101
Mike's Avatar
Mike
Originally Posted by iclick
Yeah, but it was a good discussion and I learned something. That makes it a positive for me, although others might be rolling their eyes around by now.
Old Jun 14, 2010 | 05:46 PM
  #102
BoomerBob's Avatar
BoomerBob
Question: How would the 255's do in a light Softail like the Night Train in your opinion?
I'm thinking if it does great in a heavy touring bike they should really make a lighter bike get up and go. Maybe even hard to keep the front end on the ground if really getting on it.
Old Jun 15, 2010 | 05:20 PM
  #103
iclick's Avatar
iclick
The best tuner at my local dealer uses 255s in his Dyna and loves them, but I think that although they would work well they wouldn't be quite the natural fit that they are in a touring bike. Since the smaller bikes are lighter the impact of having reduced low-end performance you see with many performance cams in an otherwise stock engine would be less, IMO. I believe the penchant for a strong low-end with 255s is not as important for the smaller bikes and a slightly peakier cam would be acceptable for more of these riders than would be the case for those with touring bikes. My 2˘.
OTOH if you want a torque monster, don't care much about peak-HP, and don't necessarily want to make other engine upgrades (compression, c.i., etc.) the 255 should be at or near the top of your list.
Old Jun 15, 2010 | 07:31 PM
  #104
BoomerBob's Avatar
BoomerBob
Thanks iclick. If I'm reading this thread correctly; the 255's do their thing in the 2200-4200 range where most big twin riders live. Seems to be a good fit for any big twin "cruiser" rider. Now if someone likes to keep the rpm's in the 4-6k range I'm sure there are better cams.
Howabout the new Andrews 48? Any good news about it yet? Maybe that question is best left to another thread.
Old Jun 15, 2010 | 10:57 PM
  #105
iclick's Avatar
iclick
The 255s provide a flat torque curve all the way out to the redline (6250), but their forte is between 2000-4500, IMO. Some think they "hit the wall" at 4500 but this is not the case, as they make more HP than stock and pull all the way out, just not as much above 5000 as most other performance cams.
How about the new Andrews 48? Any good news about it yet? Maybe that question is best left to another thread.
The specs are close to the 255s and I would love to see a dyno chart on them.
Old Jun 16, 2010 | 06:04 AM
  #106
Clump's Avatar
Clump
Here's my 103/255 dyno sheet. You can see the torque curve falls off dramtically above 4.000 RPM. The butt dyno doesn't feel the roll off though, it feels like it keeps pulling hard up to redline. It would be great to have the torque not roll off, but the 255 cams definitely have it where you live on the street.
Old Jun 16, 2010 | 06:35 AM
  #107
smokindave's Avatar
smokindave
[QUOTE=iclick;6868448]The 255s provide a flat torque curve all the way out to the redline (6250), but their forte is between 2000-4500, IMO. Some think they "hit the wall" at 4500 but this is not the case, as they make more HP than stock and pull all the way out, just not as much above 5000 as most other performance cams.
That statement doesn't seem to hold true as the dyno results posted by "Clump" show them dumping the TQ at 4k. I have seen other dyno's showing the same. Any cam is going to make more HP than stock. If you want to feel power, ride a bike that shows the TQ flat out to redline with the HP continuing to climb. It's the HP that gets you there quicker. JMO
Old Jun 16, 2010 | 07:29 AM
  #108
FX4's Avatar
FX4
[QUOTE=smokindave;6869291]
I agree with smokindave, I keep bouncing off the rev limiter because I'm there that fast. I do not feel the roll Clump's dyno sheet shows. I'm sure I'll stop hitting the rev limiter once I get used to this cam but I can honestly tell you I don't feel a power roll off. I wonder what these folks are running with this roll off are running for pipes, air cleaner, and tuner? I'm betting my dyno sheet won't peak like that.
Old Jun 16, 2010 | 07:42 AM
  #109
uscanuck's Avatar
uscanuck
Looks like from the dyno sheet he's running D&D 2-1, SE heavy breather and supertuner.
Old Jun 16, 2010 | 11:14 AM
  #110
Dennis Murawski's Avatar
Dennis Murawski
My dyno sheet for my 2007 FLHS shows that torque begins to fall at 4000 RPM, but not nearly as precipitously as Clumps. I'm running the SE 255s in a 96 inch motor with SERT, SE slipons, and 2009 exhaust pipes. While I will occasionally visit the land of "Above 4000," I live in the land of "Below 4000."
