Air pump on Road King shocks?
Old Jun 10, 2005 | 01:58 PM
wildwill's Avatar
wildwill
Default Air pump on Road King shocks?
Has anyone tried to add an air pump to the Road King rear shocks (to make them adjustable on the fly like the air adjustable suspension on some choppers)?
Does any aftermarket company make such a thing?
Old Jun 10, 2005 | 02:24 PM
HDF Tech's Avatar
HDF Tech
Default RE: Air pump on Road King shocks?
Sorry duplicate post
Old Jun 10, 2005 | 02:30 PM
HDF Tech's Avatar
HDF Tech
There are a number of HAND PUMP units available even from the dealer that have a gauge on them and are a no loss air valve, run about $60. Think it would be a project to install an electrical pump.
They look like a large seringe with a gauge on it and work well. You also DO NOT want to use air hoses in gas stations as you will blow the shock. It is low volume/low pressure only
I think J&P cycles or dennis kirk has them also.
Progressive Suspension Gauge-Mounted Air Pump
Perfect for air shocks, forks and emergency tire repairs
Simple to operate and extremely accurate
Available in two styles for servicing high-pressure pneumatic systems
An exclusive "let down valve" allows for minor adjustments
Check valve ensures no-leak operation
Part # OUR PRICE
CC20135 0-30 PSI Gauge-Mounted Air Pump $35.95
CCGP060 0-60 PSI Gauge-Mounted Air Pump $35.95
Go to HOW TO ORDER page
PROGRESSIVE SUSPENSION MICRO POCKET PUMP
Measures 4 3/4" long with 15cc of air per stroke to 200 psi
Sets pressures on air shocks, air forks and other high-pressure devices
Part # OUR PRICE
CCPP15 PROGRESSIVE SUSPENSION MICRO POCKET PUMP $13.95
available here
08ClassicRider
Air Suspensions
Jan 19, 2021 07:39 AM
firefighter156
2014-2024 Touring Models
Dec 30, 2017 08:12 PM
agent58
Apr 30, 2008 01:53 PM
harpoon
May 23, 2007 12:28 PM
twoseas
Nov 16, 2005 04:24 PM
