air pump
Old Apr 30, 2008 | 07:20 AM
agent58's Avatar
agent58
Default air pump
Just got my roadking last week.After putting air in my rear shocks using the harley pump I tried to let some air out. I pushed on the black button and thought that would release air.Nothing happened .Anyone know how this works.Thx for any help.
Old Apr 30, 2008 | 07:38 AM
jdag's Avatar
jdag
Default RE: air pump
There is so little air in the shocks that I don't think you will ever hear the "pfffft" when releasing the air. That's a reason to use the HD shock pump and not a normal bicycle pump or a gas station pump as they can blow out the shocks.
OD_Cleaver's Avatar
OD_Cleaver
When you depress the valve, try bringing it out slightly to release some of the air pressure. Do it gradually and if it behaves like mine, you will find a spot where the air is released.
Old Apr 30, 2008 | 12:38 PM
MACK's Avatar
MACK
Sometimes you actually have to grind down the fitting a bit as the valve releases all the air before youcan get the valve off .
Old Apr 30, 2008 | 12:41 PM
FLHT's Avatar
FLHT
Mess with the button a little bit. Mine will release air with about a half way push of the button.
Old Apr 30, 2008 | 12:43 PM
Geoff's Avatar
Geoff
ORIGINAL: MACK
Good point. That's whatHD tech told me they do.
Old Apr 30, 2008 | 01:33 PM
MyFirstHD's Avatar
MyFirstHD
If you buy the cheaper Pricepoint air pump they're talking about in the other thread, you just push the bleed button and watch the air pressure gage go down.
Old Apr 30, 2008 | 01:53 PM
captjon37's Avatar
captjon37
It is designed this way because there is so little air in the shock. keep pressing the valve in and out until desired pressure is reached. My harley pump works the same.
firefighter156
2014-2024 Touring Models
Dec 30, 2017 08:12 PM
PDDGM
Apr 1, 2012 04:05 PM
Mixter
Mar 4, 2011 09:49 PM
jannie
Apr 4, 2008 06:07 PM
hdjoe88
Sep 6, 2007 09:35 PM
