will running lean damage the engine?
Sea Foam not making a difference yet. Might even be getting worse.
Still, I get a lot of popping on decel, rough idling, coughing from the air filter, and jerking when in low gear. Even has cut out at stop signs.
Just bought the bike earlier this year; the fuel may have sat in the tank for a long time, maybe even more than a year.
If Sea foam doesn't work, my next thing is to remove tank and check fuel filter. If not that, then maybe take it in for a dyno test, etc.
But in the meantime, how hot can I run the bike without damaging the pistons? Can I ride for 20 miles, 100 miles? Or is it only long-term heat that will create damage, like if I keep it running lean for six months or a year? But if I only run it lean for a while until I figure it out (even if I ride 100 miles-plus), am I OK with that?
It's gonna be hotter than hell this weekend, 90 degrees or more, and I want to go on a charity ride, which is about 50 miles.
Am I OK with this, or am I doing damage?
FYI, I rode Triumph for years, got tired of wrenching on it every day, switched to Honda for the past 20 years. But now that I have my HD RK, I am in love with it, and will put up with this kind of crap to keep that thunder under my seat! I wouldn't even put up with that crap from my wife, but I will from my Road King!!
Running Lean is bad for any motor,score pistons and rings and walls,run hot bla bla bla........Best to dump all stuff out go with New gas without additives and get a tune up.......
Is one plug whiter than the other? If so, look around the intake area for a leak that lets air in - look around the intake port for a loose nut, broken stud, cracked intake, etc. Are both plugs equally white? Maybe she's running lean because a prior owner put on a big air cleaner and good mufflers, but did nothing to adjust the fuel management system to compensate for the extra air moving through.
Running serious lean can do serious damage. Running a little lean can do damage over time.
Skip the ride & fix the bike.
JR
