Changing handlebars -- Molex connectors
Here's a basic Molex connector.
Next, trying the old paperclip trick. Works, but not very well and is time consuming. Notice the relationship between the pins and the release holes.
The locking plate removed. The shiney things are the tips of the pins. Notice just adjacent to the square shank of each pin is a small plate with a half-moon notch in it. These have to be lifted to release the pins.
A quicky homemade tool. A piece of scrap aluminum or wooden dowel will work. Drill the dowel with a number drill that fits into the release holes and then turn the drill around and glue it in the dowel. What is hard to see is the the end of the drill is then ground to a sharp point.
The tool goes down into the connector and lifts the plate. It's a little fuzzy but you can see the tool has lifted the plate compared to the one next to it and the pin is released.
Here's how the tool will actually look in use. Stick it in the release hole and then angle it back so the tip goes into the little half-moon and a gentle push and the pin comes out.
Nice job pettifogger.
lp
http://www.amazon.com/Sunbeam-Molex-.../dp/B001KQDS6G
And you put the sharp end of the needle in the connector, not your finger.
lp
Broke off a sewing needle and then got out the dremel and worked over one of those cheap little tools Dawg mentioned in another thread and finally got them out.
Most of them were in mighty damn hard, took a lot more force to get them out than I expected but they are all out and no damage.
Anyway, this post by Pettifogger helped me out so thought I would give it a bump in case it helps anyone else. I think there are a fair number doing bars this weekend from the posts so figure anything might help.
Thanks Pettifogger, good post
P.S. You guys doing those with paperclips are some bad asses, no way mine would have come out like that!
It was a bitch, but it came out fine and everything worked the correctly when hooked back up. Throttle by wire was the hardest part because you have to run two sets of wires from different starting points in the right hand side and its not easy. I also had to learn how to extend the wires as my new bars called for a plus 2" in length. I should also note that I'm not the guy who normally does things like this and was scared ******** throughout the whole process, but glad I gave it a whirl. Give it a try guys and you will be happy you did...looks so much better when completed.
