Trying to change spring on my latch
Old Jun 6, 2010 | 09:55 PM
yank's Avatar
yank
Default Trying to change spring on my latch
I am trying to change my latch spring on my saddlebag lid and cannot seem to get the rod that the spring goes on. is there any secrets. seems like an allen head screw but it too small to see.
Old Jun 6, 2010 | 10:09 PM
pittz5's Avatar
pittz5
It is a PITA for sure. I cant remember but I think they are tack welded. I drilled the ends open and used the drill bit to pound the rod out. Its hard to believe how long it took to change that little spring...
Old Jun 7, 2010 | 01:24 AM
RKKY's Avatar
RKKY
Changed one at the shop last week. I just pulled the rod out with a small pair of needle nose pliers. Moved the spring to one side, grabbed it and it moved about a 1/4 of an inch. Repeated several times until it was out enough to grab it from the end.
Old Jun 7, 2010 | 08:46 AM
Harleypingman's Avatar
Harleypingman
One end of the hinge is open with a crimp to secure the rod. If the rod won't come out using needle nose pliers at the spring, you need to open the criimp end using a flat-blade screwdriver. The rod can then be moved using the needle nose pliers at the spring until the end clears the crimped end and can be removed by pulling the end.
It's shown at page 2-107 of the 2004 Touring Models SM.
Old Jun 7, 2010 | 10:42 AM
yank's Avatar
yank
Thanks I appreciate the help!
Old Jun 7, 2010 | 10:44 AM
mnskip's Avatar
mnskip
What he said.
Old Jun 7, 2010 | 12:01 PM
Retrop's Avatar
Retrop
Harleypingman has got it correct. Although I will add that spreading that piece of metal out with a screwing driver can still be a little tough. You might want to wear a pair of leather gloves and have a list of expletives handy to use, cause you will need them.
studiopeg
May 29, 2014 01:23 PM
pxs130
Sep 18, 2010 09:36 AM
billybobsrk
Aug 15, 2009 05:22 PM
