Tire changing help needed. Abs question
Old Jun 10, 2010 | 12:53 PM
Bradley Jones's Avatar
Bradley Jones
Default Tire changing help needed. Abs question
Just got the tire I ordered in today and I was going to hit up the Indy to get it swapped but I have two options, they do it all for "X" amount of money or I bring just the rim and tire and have it done for half that "X" amount. I've never tried a tire change on a model equipped with ABS so I'm afraid I might mess something up. Should I be safe an let the dealer do it or is it no diffrent than a non abs model and I'm worrying for nothing? Thanks guys/gals!!
Old Jun 10, 2010 | 12:55 PM
dawg's Avatar
dawg
You're worrying about nothing. There is only a sensor that you remove that would be just like removing a spacer. The encoder is in the bearing, but you're not messing with that.
Old Jun 10, 2010 | 12:56 PM
dawg's Avatar
dawg
Change the whole shabang yourself and use dynabeads and save even more money.
Old Jun 10, 2010 | 12:59 PM
Bradley Jones
Thanks for the pep talk!! Okay I'll take it off myself then.
Old Jun 10, 2010 | 01:06 PM
FastHoss's Avatar
FastHoss
Just pay attention to what you are doing,like where spacers go.It's not too bad if you have the manel.
Old Jun 10, 2010 | 01:38 PM
bdp's Avatar
bdp
Make sure you lay the sensor back in there where it goes and the wires are not in a bind.
Pretty easy front or rear.
Old Jun 10, 2010 | 01:44 PM
roadgliderick's Avatar
roadgliderick
to make it that much more easy remove one caliper on the front so when u put the wheel back on u dont have to fight aligning the front wheel to the calipers. and then put the other back on. just my 2 cents.
Old Jun 10, 2010 | 04:59 PM
Bradley Jones
thanks again guys
giacomo56
Apr 11, 2017 07:07 AM
Mr_Odz
Oct 20, 2016 09:40 AM
Kelowna Steve
Wheels/Tires
May 26, 2012 10:15 PM
t-bear
Jan 12, 2012 12:51 AM
lecomte38
Mar 18, 2008 07:49 AM
