Plasma Rods
Old Dec 3, 2013 | 10:53 PM
  #121
mainboom150's Avatar
mainboom150
I got them on my bike .. but since we have so many people with them does anyone else have like a white film on the saddle bags from the heat of them ?
Old Dec 4, 2013 | 03:53 AM
  #122
marvincbr's Avatar
marvincbr
I have white film/markings on the inside of my left bag. Not from heat, but the bag rubs on the plasma rod. The while film is from the plasma rod housing. This will be one of the things I am addressing this winter.
Old Dec 4, 2013 | 04:22 AM
  #123
davidw221's Avatar
davidw221
My previous post mine rubbed on my speakers I have in the bags, and one actually fell off, so I took them off, I'd love to have mine back on but my left side bag is limited on space, I only need a 1/2 inch of space for my Plasma Rods to work.
I sure would like to find a way for the left side bag to extend outward.
Old Dec 4, 2013 | 04:02 PM
  #124
14 FLHX's Avatar
14 FLHX
Originally Posted by dh2683
See post #1 on the quarter round. I didn't use it though. I siliconed mine to the verticle saddlebag supports. They kinda fit right in the groove of the support. I think they are much brighter looking strait on at them versus a side view if you use the quarter round. Just my opinion.
Here are the pics.
I got my CD stuff today, i dont like the 3\4 round idea, but i like the silicon idea. I was thinking of fabbing up a 3\4 x8" flat stock and tack welding 2 bolts in place where there are holes. How is the silicon holding up? still firm? how long\miles has it been on there?
Old Dec 4, 2013 | 04:05 PM
  #125
14 FLHX's Avatar
14 FLHX
did you try to loosen the rear saddle bag bracket (black tube) and pull it out a little? Looks like there might be a little wiggle room.
Old Dec 4, 2013 | 06:40 PM
  #126
dh2683's Avatar
dh2683
Use 100% pure silicone and clean N prep both areas is key. Only 200 miles on mine. But not expecting any problems. If i do i like your idea on the bolts. Time will tell.
Old Dec 4, 2013 | 06:50 PM
  #127
Overdoo's Avatar
Overdoo
Default Plasma Rods
The whole reason behind the 3/4 round mounting method was to provide a wide bonding surface. Brightness was not significantly affected and it didn't effect the paint. Custom Dynamics uses double sided tape on the side of the rounded bag fillers. For my money the gluing surface area is far and away smaller than with the 3/4 round method. Mine have been on since I made that original post in 2010 with no issues at all and the paint has not been damaged by any sort of bonding material. That's just my opinion of course but it has definitely worked for me!
Old Dec 5, 2013 | 07:56 AM
  #128
vonzoog's Avatar
vonzoog
I have to agree with Overdoo. I also use the three-quarter inch molding as a mounting system. Mine have been on for over two years now without any problems whatsoever. I mounted the three-quarter inch molding with 3M tape. This is a quick, simple, easy, and cheap way to do it. It works.
To each his own and everyone can do what they like. You do not need to overthink this project. It is simple and easy to do. Just my two cents worth.
Old Dec 5, 2013 | 09:01 AM
  #129
mainboom150
normally there is only about a 1/4 inch inside the tube that connect so there is no "wiggle room". plus 2014 bikes are completely different then any later models. so the likelihood anyone else's saddle bag hanger is like your is very slim unless its another 2014. seeing as though Harley made it so the 2014 bike part cannot be used on a later model or visa versa
Old Dec 5, 2013 | 03:05 PM
  #130
14 FLHX's Avatar
14 FLHX
I got the plasma rods installed and wired up. Im headed to bed now, i work nights. Ill post up some pics friday.
Attached Thumbnails Plasma Rods-image-3081049225.jpg   Plasma Rods-image-3499391704.jpg
