Rear drive belt
Old Jul 3, 2010 | 07:10 PM
DPete's Avatar
DPete
I just push with my thumb what I think is 10 lbs and watch the scale on the guard then give it the 1/4 twist test when done. Works for me
Old Jul 3, 2010 | 07:33 PM
07RoadHawg's Avatar
07RoadHawg
Originally Posted by malbanese45
My 2010 manual states ''measure deflection at several locations around the belt. Select the loosest measurement and compare with specifications.''
1/4-5/16 for FLHX,FLTRX
3/8-7/16 for other models
I've always been taught that a loose belt belt will fail faster than one slightly tight.JMHO.
While that might be true about the belt failing (I have no idea if it is or not) an over tight belt will stress the seals and bearings more. I'd rather replace a belt than have bearings and seals fail. Both are costly repairs, but I'd rather err on the side of a slightly looser belt. JMHO.
Old Jul 3, 2010 | 08:56 PM
atrain68's Avatar
atrain68
The first time I adjusted my drive belt, I tightened to specs. The belt whined once it warmed up. I readjusted letting the deflection decrease about 1/8 of an inch and the problem was solved.
If you use a black sharpie pen and mark the adjustment cam at the right setting it makes it much easier to adjust the belt later. This came in handy after a recent tire change.
Old Jul 3, 2010 | 10:19 PM
SteveO's Avatar
SteveO
Changing the shock pressure will change the belt tension. Manual says how much air to put in the shocks before checking the belt at ambient temp, on the side stand with a Harley belt tension gauge in the center of the belt................after several beers!
bogie
14
Mar 23, 2022 08:56 AM
HDF Tech
Sep 28, 2017 08:54 AM
Jazzhog
Jun 27, 2011 01:41 PM
cpd2442
Jun 2, 2010 07:05 PM
smithr
Aug 20, 2007 02:26 PM
