Slip on/off help
Old Jun 18, 2010 | 07:30 AM
FLHRC in NJ's Avatar
FLHRC in NJ
1st Gear
Default Slip on/off help
Just picked up a pair of slip on pipes. While the installation seems pretty straight forward, is there a trick to getting the old ones off without messing up the chrome finish or do I just have to muscle them off? Thanx.
Old Jun 18, 2010 | 07:46 AM
larsfum's Avatar
larsfum
Loosen torca clamp. Remove rear bracket bolts. Wiggle back and forth (the muffler, not you). Should slide right off with a little effort.
Old Jun 18, 2010 | 07:53 AM
FLHXterp's Avatar
FLHXterp
You can spray a little PB Blaster or WD40 at the joint first and let it sit for a bit, that'll make it need less "elbow grease".
Old Jun 18, 2010 | 09:00 AM
Scooter_092196's Avatar
Scooter_092196
I have also loosened the clamps, started the bike and ran for a few minutes to get them warm and they slip right off. Just need to use a good set of leather gloves to handle the warm pipes.
Old Jun 18, 2010 | 09:06 AM
frog13's Avatar
frog13
I've never done it that way, I would assume the inner pipe gets hotter and expands faster, essentially making it tighter. Or I could be way off base, just my thought. I use PB Blaster and wait a few minutes, they usually pop off pretty easy, then there are those that become nightmares, also.
Old Jun 18, 2010 | 12:08 PM
Scooter_092196
I've actually never used this method on a touring bike. I did however have to use this methond on my 99 Heritage Softail. I couldn't get those slip-ons off to save my @$$. Tried PB blaster, hammer/block of wood, whole nine yards. Started her up for 2 minutes and they slipped right off.
Hot Rod King
Mar 15, 2013 10:04 AM
neversatisfied
Jul 10, 2010 08:09 PM
tyson
Jun 2, 2010 07:30 PM
Tarponrod
Exhaust System Topics
Mar 19, 2009 12:39 PM
6165hd
Feb 18, 2009 07:01 PM
