new frame vs old
I'm waiting for the next big change before I "upgrade".
The old frames can be made to handle very well. The right tires and a swingarm brace will make a world of difference. I have ridden both (as have just about anyone who's bought a new one). The new bikes ride better than the older ones to a degree, but it's not the quantum leap forward some people would say it is.
You gotta decide what's more important. I put together a very fast bagger on a budget. I worked on it with my own two hands and own it outright.
But the new frames are nice. Maybe I'll get one someday.
I agree. But while putting bandaids on a problem can make a big improvement, its never as good as not having the underlying problem to begin with.
Im not advocating everyone with an 08-older bike dump the thing and run out and buy a newer one. But for someone who is looking to buy a bike NOW, (as the OP is) IMHO they would be NUTS to not get the newer design, with a couple of exceptions:
1. Riders with shorter inseams who would have a hard time getting their feet down on the newer, wider bike.
2. Someone who simply cannot afford the newer models.
Its not just the frame/bagger waggle issue. There were a LOT of smaller, less talked about changes in 09:
1. They have the bigger tank (as do the 08s)
2. They have MUCH better brakes, even if you dont do the ABS option (as do the 08s)
3. The shocks have been beefed up--my prior bikes ALWAYS felt overloaded when 2up and loaded, no matter if the shocks were pumped all the way up.
4. The larger rear tire... more rubber on the road, not the mention the looks.
5. Overall load rating increased (see #3)
6. Higher load rating for the luggage (15 more pounds)
7. Front end tweaked for better handling and stability... being a batwing rider, I have to say my 09 has almost NONE of the batwing waggle when stuck in semi turbulence that all my prior bikes had.
8. better exhaust routing for less heat (it DOES help)
9. rear jug cutoff when stuck in traffic (it DOES help)
More subtle:
1. saddlebags moved back half an inch, more room for passengers legs
2. rider backrest brackets tweeked so your not sitting so far upright as prior years
3. No hoop over rear fender... cleaner look
4. For those with tourpaks, much simpler, cleaner, stronger mounting bracket, not a bunch of parts bolted together
5. Cleaner quick detach mount points, and MUCH easier to install
6. frame mount heat deflectors MUCH easier to install
7. MUCH better looking wheels (subjective, but most seem to agree)
And some more Ive discovered, but cant think of at the moment.
The only thing I DONT care for, is the throttle by wire. Id just as soon have cables, not the mention the throttle response change programmed into the ECM.
I paid cash for my current bike last summer, and have made all the improvements out of pocket. I could have bought a new bike on a payment plan, but I don't like incurring debt.
09+...not so much. Way better design. Having had both styles, I prefer the newer models. I like the older bikes too though.
lp
Glad you were able to pay cash for yours. Would be great. Wish I could have. For my car and house too. Unfortunately, 99.9999 percent of the population is NOT in that boat. I guess NONE of us should be riding.
"if they couldn't pay cash, they can't afford them"
