monkey bagger bar clutch issue?
Old Jun 20, 2010 | 10:23 AM
streetclyde's Avatar
streetclyde
Default monkey bagger bar clutch issue?
Curious.Is anybody have any clutch issues with there clutch after installing the Yaffe monkey bagger bars? My clutch is very stiff and ingages all at once.Hard to feather at a complete stop.I was wondering if its the extra bends in the cable as it makes its way to the fairing hole?The cable that I bought from Dr.Vtwin came up a little short so we had to let it out a lot to make it work.I have had to adjust it several times and there is a fine line between working and not working at all.Thought I had it adjusted when I came off the highway last night and couldnt fully disengage at the stop light.I cant afford a hydraulic clutch at this time and hope somebody can shed some light on my problem.Thanks guys for any help.
Old Jun 20, 2010 | 10:30 AM
PistonPuller's Avatar
PistonPuller
Make sure you have about 1/16 to 1/8" play between the cable and the perch, also did you adjust the clutch pack as well?
Old Jun 20, 2010 | 11:18 AM
hog-doc's Avatar
hog-doc
What do you mean by "you had to let it out a lot"?
If the cable is short screwing with the adjustment ISNT going to make it work!
Old Jun 21, 2010 | 09:48 AM
smharris605's Avatar
smharris605
my clutch was tight after i put my wild 1 12.5 bars on as well. i opened up the clutch cover on the primary side and adjusted my clutch. after that, it felt just like stock. hopefully this helps!
Old Jun 21, 2010 | 09:54 AM
SDVmnt's Avatar
SDVmnt
Make sure it's been lubed if it's a non-teflon cable. That improved mine significantly. Also make sure there's no tight bends. If those are ok, it just needs a full adjustment. Mine is better than stock now.
Old Jun 21, 2010 | 09:56 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
So we got you a cable that was not long enough? This is the first I have heard about it. IF it is too short, it is too short. PM me so we can get his figured out please.
Drew
Old Jun 22, 2010 | 10:52 PM
streetclyde
The cable is just barely long enough not insulation part the actual cable inside.The adjustment on the cable is screwed all the way in except about a turn or so but after adjusting the clutch pack and lubing the cable its works fine.We were tired and in hurry that night trying to get ready for a weekend camp out plus too many beers.Tomorrow nights task to get the dam heated grips to work.Riding to Minnesota sunday morning.Thanks guys for your help.
rick775472
Jul 5, 2015 09:08 PM
mi2az
Aug 1, 2011 06:03 PM
jeffwest5599
Nov 22, 2010 11:22 AM
streetclyde
Jun 20, 2010 10:48 AM
davisrf
Apr 23, 2008 06:28 AM
