I have been searching and searching to see what the story with the states light on the PCV are for. With a key on and pump running I get a power light and a flashing status light. With the bike running I get just a power light. Is this normal? I am pretty sure it is working as intended but I am just unsure about the status light.
FWIW, mine does the same thing. The "Power Light" is on whenever the Ignition/Headlamp key switch is in the "Ignition" position and the Kill/Run switch is in "Run". Whether the engine is running or not.
However, the "Status Light" only flashes about 3-4 times when the kill/run switch is initially put in the "Run" position. It then goes out even before the engine is started. Mine also remains out while the engine is running.
Thanks for the reply back on this. I did in the end call Jamie at Fuelmoto and he said all is good to go. I was just pretty new to the PC and curious. Guess I should of updated the thread. Glad yours does the same thing.
