Pcv and check engine light
Old May 24, 2009 | 06:06 PM
Bigwillie's Avatar
Bigwillie
Default Pcv and check engine light
i installed a pcv from fuel moto with a SE stage 1 a/c kit and k&n filter, i`m getting some decell popping, but i am more concerned about the check engine light. when i turn the bike on the light come on as is normal when the light goes off i start the bike. AFTER I START THE BIKE THE CHECK ENGINE LIGHT COMES BACK ON FOR ,5, 6 SECONDS THEN GOES BACK OFF.
anybody have an opinion way this is happening? should i not ride the bike? should i put the bike back to stock and see if the light stay`s off? Thank`s
Old May 24, 2009 | 07:30 PM
Roadie09's Avatar
Roadie09
clear the engine codes and try running the bike. Mine did the same thing after installing the PCV, clear codes and no more light. It is still popping on decel, I will address that problem later.
you can search this site for info on clearing the codes.
Old May 24, 2009 | 07:37 PM
Bigwillie's Avatar
Bigwillie
thank`s syclone!
Old May 24, 2009 | 07:43 PM
beracing's Avatar
beracing
Everyone says to contact Jamie if there are issues. They're really good to respond. I'm sure there may be a tweek on the settings causing the pop. Usually it is the other way around. It stops it, not creates it....
Old May 26, 2009 | 05:27 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
If you are getting the engine light for 5 seconds when you start the bike and it then goes out your bike has a stored code and is completely normal, likely from unplugging the ECM or from the TPS. This is not a current code and is not a problem. This will clear in 50 engine starts or it can be cleared thru the gauge pack. I do recommend if you have a pre-08 bike checking and resetting the closed throttle position setting with the PC software. If you have any questions feel free to contact us at 877-729-4754
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old May 26, 2009 | 07:59 PM
SC_Compact's Avatar
SC_Compact
I just finished a 2000 mile trip on my 2009 FLHX. I have the Fuelmoto package on my bike and it runs very well. I have a little decel popping at low rpm but the bike runs exceptionally well the entire trip and I averaged 40 mpg.
One of the stops was at Rolling Thunder on Sunday. After sitting in traffic waiting to move forward I shut the bike and turned it back on rather quickly. The throttle went into limp mode and would barely move the bike. I shut it on and off via the kill switch a few times and the bike then started fine.
Now when I turn the ignition on the light goes out but comes back on for a few seconds after I start the bike but it runs fine. I called the dealer and he said to bring the bike in and they will check/clear the code(s).
shore
Milwaukee Eight (M8)
Oct 17, 2017 07:15 AM
Allen Riggs
Aug 23, 2013 01:20 PM
mrfikser
Sep 24, 2012 08:11 AM
2wheeltom77
Mar 27, 2010 09:16 AM
BillyG0856
Mar 11, 2009 08:25 AM
