Update on PC V and HD Engine Codes
Old Mar 10, 2009 | 07:25 PM
BillyG0856's Avatar
BillyG0856
Thumbs up Update on PC V and HD Engine Codes
This is a link to my thread about the PC V.
https://www.hdforums.com/forum/touri...4619-pc-v.html
Today, I rode the bike to and from work....there were NO ENGINE CODES....all listing "NONE"!!!!! Granted, it's not that long of a ride in either direction...but Im feeling MUCH BETTER about the PC V upgrade. The bike's running like never before. Crisp throttle response....really noticable in 4th and 5th gear. 6th gear & 85 mph is a whole 'nother world.
I cant say enough good about Fuel Moto. When I talked to Keith yesterday, he was sending me another set of terminals/eliminators....no questions asked. They'll definately get my business from now on.
Thanks to you guys here on the forum for your suggestions. Special thanks to 09 Streetglider for posting the link about the codes...otherwise I'd still be 'wondering'.
Billy G
Old Mar 10, 2009 | 07:29 PM
09StreetGlider's Avatar
09StreetGlider
No problem man, that's what we're all here for. Let us know if you have any more trouble. Glad it was an easy fix.
By the way, you didn't happen to start the engine without the eliminators installed when you were putting in your PCV did ya? If you got anxious and started up without the eliminators maybe that would have been enough to throw a code... Just guessing...
Old Mar 10, 2009 | 08:10 PM
QIKLUV's Avatar
QIKLUV
i have noticed this weekend that my tach stops climbing at 5000rpms... i meen the needle just stop but the motor is still pulling...this is after the PCV install.
also after it starts ...for about 5-8 seconds the engine light comes on then goes off after 2 seconds???
anyone have this problem???
Old Mar 10, 2009 | 09:22 PM
09StreetGlider
I doubt this is related to the PCV install. Check the codes via the odometer check for your year. I would bet either the tach or the sender is going bad. Maybe someone else could say for sure...but if your light is coming on at the same time then there is going to be an associated code to lead you in the right direction.
The light going back off after a few seconds would indicate the problem has rectified itself, and the code will be historical...so your trouble is probably intermitent and could be a warning of impending complete failure of whatever the historical code points to.
Old Mar 10, 2009 | 09:27 PM
rg_dave's Avatar
rg_dave
I noticed the same thing with the tach. Spoke with fuelmoto on the phone. Give them a call they can explain it to you. Bottom line nothing is wrong.
Old Mar 10, 2009 | 09:33 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
With the Rev Xtend enabled on 08-09 DBW bikes with PC III USB or PC-V the tach needle will only read to approx 5100 RPM due to the strategy the PC module uses to raise the rev limiter. The actual limiter will be 6200 RPM's. Your engine light sequence means it has a stored code, which can be due to a number of things including setting the throttle position with the PC software. This is a non issue as long as the light is not staying on and it will clear itself in 50 engine starts.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Mar 10, 2009 | 09:39 PM
09StreetGlider
Wow...I hadn't heard that one yet. Thanks Jamie.
Jamie...Is mine not doing this because of the ECM download that came with my 103? I think they said my rev limiter is now 6200 due to the download and though I do not have rev-extend enabled, I have pushed it past 5500...but my tach worked fine and no codes were set.
Old Mar 10, 2009 | 10:17 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Correct, this would only apply to 08-09 bikes with a stock ECM calibration, note this will not cause codes for any reason.
Old Mar 11, 2009 | 03:53 AM
BillyG0856's Avatar
BillyG0856
Posting this link for those who might be curious what 'diagnostic codes' are active when the check engine light comes on. Has a good write-up about how to get to the diagnostics via your speedometer.
http://www.hdtalking.com/diagnostics...ctivation.html
Billy G
Old Mar 11, 2009 | 08:25 AM
JustDennis's Avatar
JustDennis
Hope it stays clear.
shore
Milwaukee Eight (M8)
Oct 17, 2017 07:15 AM
jake.mason.2
Jul 28, 2014 09:48 PM
Allen Riggs
Aug 23, 2013 01:20 PM
2wheeltom77
Mar 27, 2010 09:16 AM
Bigwillie
May 26, 2009 07:59 PM
