I phone radio help ( interferance)
Old Jun 21, 2010 | 09:51 AM
ANIMAL03's Avatar
ANIMAL03
Default I phone radio help ( interferance)
ok heres the deal when i plug my iphone into my radio aux port i get a lot of interfance. any idear on how to cure this problem. thanks
Old Jun 21, 2010 | 09:57 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Have you tried a new cable to plug it in with? When trouble shooting always start with the physical connection.
Drew
Old Jun 21, 2010 | 09:59 AM
jurob's Avatar
jurob
If cable doesn't work try lowering the volume on the phone to just over half and use the radios volume to raise the volume
Old Jun 21, 2010 | 10:13 AM
drew4jan's Avatar
drew4jan
If it is scratchy then replace the cable, if it sounds distorted then turn down the volume on the iPhone and use the radio volume jurob said.
If the iPhone is set too high or "hot" it will be more than the small speakers on your bike or in your helmet can handle and cause distortion and eventually blow them. First rule in electronics troubleshooting though is to check the weakest link which is the cable as the good Dr. said.
Old Jun 21, 2010 | 11:21 AM
ANIMAL03's Avatar
ANIMAL03
i will try both, the volume sounds like the culprit. i have it maxed-out. i'll start there. thanks. ANIMAL.
Old Jun 22, 2010 | 03:55 PM
Theakerr's Avatar
Theakerr
There was a previous post about a Gentleman who re-placed his spark plug wires with SE wires and he said it eliminated a load of static on his intercom. Cannot remember if he said anything about phone, but it may be applicable
Old Jun 22, 2010 | 07:54 PM
cajunfla's Avatar
cajunfla
Animal, please post back if the volume controls fixed the problem. Similar problem with iPhone....I tried to use an other-than-iPhone ear buds with the phone, and it had a lot of static. i know it's not the ear buds, because they work fine on my mp3 player, and when i tried the iPhone buds in the iPhone, they worked fine. Just guessing something about compatability problems.
Old Jun 23, 2010 | 12:13 AM
sbarber7973's Avatar
sbarber7973
From experience the problem with the Iphone over just an ipod is the phone its self, being that it is a phone you are probably hearing the phone "communicating with the towers". I have had an adapter with my truck and I get the same thing. Just my opinion.
Old Jun 23, 2010 | 08:40 AM
sgdiesel's Avatar
sgdiesel
Do you have some kind of protective cover over the phone. If the jack is not fully inserted in the IPhone you can get some weird results.
Sometimes the hole in the cover is a smaller diameter than the jack which prevents it from seating properly
I always look for cables with a neat, small diameter jack
yardzoo
2014-2024 Touring Models
Oct 11, 2018 11:19 AM
Hinzy
Audio Systems
Jul 25, 2015 09:50 AM
sniper uk
Audio Systems
Jun 5, 2012 01:11 PM
frozensoul
Mar 13, 2011 11:39 PM
rmatt34
Nov 25, 2010 08:11 PM
