Bigger Throttle Body More Power?
Old Jul 30, 2010 | 05:25 PM
harry.b's Avatar
harry.b
I am building a 113" and headquarters recommends leaving the throttle body stock. they have reported issues with loss in torque or something like that going to a larger throttle body and with an 850+ pound motorcycle, the more torque the better.
Old Jul 30, 2010 | 11:31 PM
niterider985's Avatar
niterider985
To big of a TB will make your bike lazy and run like a pig. You need a big inch motor to use a 58mm. I have a 55mm HPI worked by Tman with a match ported 58mm pro manifold on my 124" motor with Tman stage 4 thumper heads and it is just rite for it talk to a good Tuner or motor man for advice because it will make a big difference in performance.
Old Jul 31, 2010 | 03:59 AM
BLKBAGGER's Avatar
BLKBAGGER
Got to agree with bigger isn't always better. Same goes for exhaust. You will lose your bottom end torque for sure. Some of the best head porters use small reshaped ports rather then hogging them out real big. It's all about velocity.
Old Jul 31, 2010 | 08:16 AM
Heatwave's Avatar
Heatwave
Member
Depends what engine work you're having done. I have the 58mm on my build (2010 SE Ultra 110 FBW) which includes headwork by Hillside. They strongly recommend adding the larger TB to go with their headwork. I also have larger injectors, roller rockers, FatCat, Ventilator A/C and Woods 408-6 cam. I couldn't be happier. The engine is explosive from a dead stop so don't let others convince you you're going to have lag and reduced velocity because of the larger TB. Not true.
I will say that the engine is alot more sensitive to tuning changes. The "window" of max performance at low rpms is a very narrow band and you'll need to get it right or you can have lag. But once you get it right, you'll have outstanding performance down low and boundless power in the upper rpms.
It all comes down to a build that can take advantage of the higher flow of the 58mm TB and a tuner that has the skill and patience to tune the map to fully utilize it without losing low-end performance. I for one wouldn't go back to my stock 50mm FBW TB (which I still have). Talk to Scott at Hillside Heads for more info on why the 58mm makes sense on the proper build (even on a 110). http://www.hillsidecycle.com/
Old Jul 4, 2011 | 07:20 AM
jimholl1's Avatar
jimholl1
6th Gear
Default 50MM vs 58MM ??
Some insight please - I have a 09 RKC, 98 motor that has:
107" headquarter kit
Polished and ported
Compression release
Kirker slip on's
High Flow Air
SE race tuner
current dyno run 104hp / 115 TQ
pulls like a freight train - very happy with current build but we are always wanting more.....
I'm being told that the next phase for more power would be to move to a 58mm throttle bottle versus my current 50mm ?
2 into 1 exhaust ( recommended D&D )
Would the above make much of a difference?
BOSOXFan
Aug 25, 2015 04:48 PM
mfortkamp
Exhaust System Topics
11
Jan 4, 2013 05:06 AM
davidw221
Feb 4, 2012 01:55 PM
scottklimite
Sep 7, 2009 07:05 PM
cccbebad
Aug 13, 2008 10:15 PM
