Throttle Body
Old Aug 25, 2015 | 01:02 PM
BOSOXFan's Avatar
BOSOXFan
Default Throttle Body
Ok, so I know it is early but I am already looking into my winter project. I was told for more power, my best be and most ban for my buck is throttle body and get rid of the PCV for a dyno tune.
Do you all agree? Or should I go all in and do the CAMS as well?
When it comes to the throttle body; what's the difference between the 58 and 62MM and which one would you recommend?
Old Aug 25, 2015 | 01:25 PM
Keithhu's Avatar
Keithhu
If you have a stock motor, I wouldnt bother with a ported or larger throttle body. Spend your money first on cams, then ported heads. After you do that, a larger TB will get you a small gain on top of those.
Old Aug 25, 2015 | 02:11 PM
BOSOXFan's Avatar
BOSOXFan
Gotta be honest, this is the first I have heard of "ported heads", hit me wit specifics cams, heads an throttle body.... ready to make her SCREAM!!
Old Aug 25, 2015 | 02:25 PM
FNGonaRK's Avatar
FNGonaRK
Call Fuel Moto and tell them what your goals are. They have the knowledge and the dyno sheets to back it up.
Old Aug 25, 2015 | 04:36 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I agree with the posts above. The absolute last thing you should consider would be a larger throttle body. Your motor needs to receive major upgrades first off then a larger throttle body can be added but the TB will only add minimal additional power. Maybe a 2-3 hp and tq gain over the stock OEM unit.
Old Aug 25, 2015 | 04:48 PM
todd-67's Avatar
todd-67
Exhaust aircleaner tuner which you already have then cams heads throttle body
SleepyBagger
Engine Mechanical Topics
May 6, 2015 06:25 PM
LowRider68
Feb 14, 2015 06:39 PM
slyedog
20
Oct 20, 2014 11:01 AM
davidw221
Feb 4, 2012 01:55 PM
Dru
Jul 4, 2011 07:20 AM
