IDS on 07 Street Glide?
STOP WHINING! It's the pot calling the kettle black. I'm not sure how or when any slack is supposed to appear, as my bike has none at all after 27k miles and almost three years. Yes, I did the check a while back as per the instructions. Anyway, even if you had to replace the rubber every time you replaced a rear tire it wouldn't add any time or effort to the job, and the rubber-bumper kit is very inexpensive.
I just recently did a 10K on an 08 and checked the pulley, it already had about 3/8" slop.
People bitch that the stock comp is weak and then install a rubber link in the driveline and defend its use!
My tranny made a **** ton of noise from day one, guess what I did? Put Redline in it at 100 miles and rode the **** out of it. And like I said in 07 "it aint gonna break" and guess what, it didnt. The onlt thing I hear is the Road Rage and the cams!
The bearing looked perfect too, although I do worry about it a bit. I've been toying with the idea of replacing it after every tire change (20k with E3 rear), but I can't rationalize changing something that shows no signs of problems. Anyway, how do I know the new bearing wouldn't be defective and fail quickly?
Like FX4 my tranny also broke, but long after installing IDS. The mainshaft bearing came apart, but I have no evidence the noise I heard pre-IDS was in any way related to it. IDS was installed at 9700 and I started hearing a while in the tranny at 16k. It whined for another 16k and got worse over time, and that's when we dug into the tranny and found the problem. Since there was no hard evidence (i.e. metal on the magnet) we blamed the belt and/or rear tire for months.
1) Would installing the IDS make a good ride better?
2) Are there any mechanical issues that can result from not installing the IDS or is it just a comfort thing?
3) Pretty handy with a wrench and own a service manual, so do you think I'll have any issues doing it myself? I've read some posts about making sure you put the correct washers in the right locations. Also read about the bolts shearing but some posts suggest incorrect installation as the culprit.
4) Anybody have any suggestions on where to buy? Seem to remember some sellers who would also press the bearing in for you.
I know this topic may be whipped horse, so I appreciate your indulgence. Getting ready for a cross country ride.
Thanks!
Chris
1. no
2. don't know. Don't care
I think it might be your admitance to riding very easy!
Most of the failures I ve seen the seal was out on the spacer allowing the bearing to get full of water and rust, keep an eye on the seal, if it moves free or grease is coming out of it, replace it!
While reading this thread, I've been wondering if the clatter would return if I returned my stock pulley back into service (i.e. no IDS) considering I installed the SE comp last September. I had no comp issues but the primary was apart for a tranny-bearing job at that time and it was too tempting. Unfortunately I can't test the pulley idea since I sold my stock one.
I put some Royal Purple 85w140 in mine early on and it helped, but not enough. I don't think Redline SPH would've done the trick on mine to relieve the clatter, as after installing IDS I couldn't tell any difference between the two gear oils. I'm using RL now because it's cheaper in this area, but that's the only reason, as both worked very well.
Which bearing on the main shaft? Theres the mian drive gear bearing, 2 needle bearings inside the main drive gear that the main shaft rides in and then the right side door bearing.
