Big Bore kit 'again'
Old Jun 30, 2005 | 10:28 PM
  #61
DGlide04's Avatar
DGlide04
Default RE: Big Bore kit 'again'
I've been following this thread for a while, good info. Getting 100+ hp and tq out of a big bore build depends on what you put into it (parts and cash). My 95" shopping list for an upcoming build:
SE HTCC Ported Heads
SE HTCC Forged Pistons
SE Big Bore Cylinders
SE 251 Cam, spacers and plate
SE Adjustable Pushrods
SE Big Bore Manifold
Initial Dyno after a Stage 1 upgrade is 74 1/2 HP and 82.9 ft.-lbs torque. Engine builder at my dealer tells me 100+ hp and tq are no problem, will run on pump gas and mileage should not be too far from what I'm getting now, if I can refrain from too much throttle. Best thing is that I've been assured that the dealer will honor the balance of my warranty, where other dealers, same build, etc. tell me it can't be done. That's the selling point for me to have it done at the dealer where I bought the bike, instead of saving a few bucks having it done elsewhere.
The bike is a 2004 FXD, otherwise stock.
Old Jul 1, 2005 | 01:05 AM
  #62
Rubberduck's Avatar
Rubberduck
ORIGINAL: terryt1955
I've got the factory installed 95 in w/203 cams, stage 1 air cleaner and Rinehart True Duals. I dyno'd at 80 hp and 87 ft lbs. I know people running the 103s that aren't getting 100 hp. It usually takes some high compression pistons and flowed heads to get that kinda power.
Good Luck
Terry
Terry,
I agree...my dealer had 1550 BB option that got right at 100hp and 100ft lbs. It took what I did to my BB option and added a different cam (more agressive grind) and ported and flowed the heads. It also programed the ECU for a slightly higher RPM range. My concern was changing the "stock" characteristic of the motor. The kit I did is just what i was looking for. It doesnt move the power too far up the rev band...and keeps the stock character of the engine.
Old Jul 1, 2005 | 01:10 AM
  #63
HDF Tech's Avatar
HDF Tech
Terry
Are you familiar with the mods taking the engine over the 100 mark and the problems that can arise with the crank bearings? They usually need to be retrofitted to the better bearing by zippers who mills the cases for the installation, just wanted to mention it before you pump it up any higher.
Old Jul 6, 2005 | 10:04 AM
  #64
Feroce's Avatar
Feroce
I drag raced my friends 03 Super Glide stage I, yesterday (rolling start) and we were equal up to 70mph then he just started to inch forward. I think if I were to have shifted to the next gear I might have went ahead again but we both backed off at the sametime. I would say wind resistance got to ME. We swap bikes sometimes and now it is very hard to get him off my bike. He got off my bike yesterday and said that is one sweet ride I could drive that bike across country very easy.
Ed
Old Jul 13, 2005 | 10:32 PM
  #65
Feroce's Avatar
Feroce
I had the bike dynoed.
4th gear r:
Max Power= 82.2 @ 5400rpm
Max Torque = 90.6 @ 4000rpm
Air fuel ratio= 13avg.
The bike is great now, fuel econ is great and power is all I will need.
Old Jul 15, 2005 | 01:39 AM
  #66
Rubberduck's Avatar
Rubberduck
[quote]ORIGINAL: Feroce
Ed
Sounds about right...power to weight is a H U G E equalizer. I thinkg the Super Glide is about 125lbs+ lighter than the EG/RK bikes.
Old Jul 15, 2005 | 01:43 AM
  #67
Rubberduck's Avatar
Rubberduck
ORIGINAL: Feroce
4th gear r:
THanks for the follow up, Feroce. Looks analogous to what I get out of my mods, which were nearly identical to what you did. Best wishes and have fun. Keep the shiny side up!
Old Aug 10, 2005 | 09:58 AM
  #68
Feroce's Avatar
Feroce
Just want to give an update.
I raced my friend with the 03 Super Glide and we were even again and he did not move ahead. My MPG has not changed since the BB maybe even a little better. The drivability is great could not ask for anything better. I don't like all the heat coming up from the exhaust so I ordered V&H true duals. I will let you know any changes in performance and MPG also try to dyno again.
Ed
Old Aug 10, 2005 | 10:04 AM
  #69
HDF Tech's Avatar
HDF Tech
Thanks for the update, do you have a dyno run before this upcoming pipe change to compare with?
Old Aug 11, 2005 | 01:03 AM
  #70
Feroce's Avatar
Feroce
I had the bike dynoed on 7/13/05 and got:
4th gear r:
I have not done anything since until now with the duals.
Ed
