fork grease zerk
Old Aug 24, 2006 | 02:52 PM
dawg's Avatar
dawg
Default fork grease zerk
If you were going to grease the forks, which way would you go...replace that friggin zerk to an angle one so my gun will fit, or just go and buy a new gun tip?
Old Aug 24, 2006 | 03:02 PM
bountyhunter's Avatar
bountyhunter
Default RE: fork grease zerk
Replace stock fitting with a 90 degree!
Old Aug 24, 2006 | 04:05 PM
swomack's Avatar
swomack
Where's the fitting and what kind of grease does it use?
Old Aug 24, 2006 | 04:08 PM
bountyhunter
Left front of steering head bearing, behind lower fairing trim....I use marine grease.
Old Aug 24, 2006 | 05:04 PM
iclick's Avatar
iclick
I replaced the grease-gun tip, as the 90° angle works better all-round for me.
Old Aug 24, 2006 | 09:04 PM
wedgewood1's Avatar
wedgewood1
I replaced my fitting on the steering head with a 90 degree fitting and use HD grease.
Old Aug 24, 2006 | 10:17 PM
1flhtk4me's Avatar
1flhtk4me
I replaced the Zerk on my '06 Road Glide with a 45 deg. Zerk.No point in buying a new tip when I had a Zerk.I used wheel bearing grease.
Old Aug 24, 2006 | 10:23 PM
bpterb's Avatar
bpterb
I also just bought a 90 degree adapter for the grease gun, and it worked perfect and made it very easy.
Old Aug 25, 2006 | 06:55 PM
Bama Harley's Avatar
Bama Harley
I replaced the fitting with a 45 deg fitting. That way I would be able to grease with any gun and not be limited to using one with a 90 deg. end. (Because I have a tendancy of losing things)
Old Aug 25, 2006 | 07:37 PM
roady's Avatar
roady
I just greased mine today with the straight fitting with no problem. I didnt think it would ever stop taking grease though. It took a good forty to fifty pumps before I started to see any grease comming out. I guess the factory missed and the dealer during the 1000 mile service.
