HK Radio and Aftermaket Radio Advice
Old 06-28-2010, 10:43 AM
1sweetglide08's Avatar
1sweetglide08
1sweetglide08 is offline
Default HK Radio and Aftermaket Radio Advice
I'm starting to have problems with my HK radio theres no volume at times and I have to turn it off and back on to get volume. It's still under warranty...but I have read so much on how the HK radio is a POS. I'm thinking of buying a aftermarket raido and a install kit so my hand controls will still work. What would you do... let HD fix it or just buy a new radio? If I do buy a new radio what's the best radio with a USB port on the front face and with LED backlight bright enough to see in sunlight?
Old 06-28-2010, 11:31 AM
vickers1's Avatar
vickers1
vickers1 is offline
In my opinion, I would stick with the HD radio. The main reason is because it is waterproof. Biketronics kit has a clear plastic piece that will cover an aftermarket radio during a storm but seems to me like it would be a pain to deal with.
On the road, I use my ipod thru a headphone amp with Shure earbuds. I installed (2) 3.5mm jacks on the bike and one for the ipod input. I burned 2 cd's in mp3 format to use during beerstops. Each cd has about 125 songs on it.
Attached Thumbnails HK Radio and Aftermaket Radio Advice-007.jpg   HK Radio and Aftermaket Radio Advice-005.jpg   HK Radio and Aftermaket Radio Advice-amp.jpg
Old 06-28-2010, 11:38 AM
robfaulkner's Avatar
robfaulkner
robfaulkner is offline
Default Get the HK radio fixed under warranty.....
then sell it if you want the Sony/Biketronics setup. You can get $500 or so for the HK on ebay. I have the Sony/Biketronics setup - works great. Yes, the plastic shield is a nusiance once in a while but its really not that much of an issue. But by all means get the HK fixed since you have warranty and it has saleable value.
Old 06-28-2010, 11:49 AM
2WheelGlider's Avatar
2WheelGlider
2WheelGlider is offline
I would definately keep getting the HK replaced or fixed as long as the warranty last. When it expires, then you can look at aftermarket head units, or try the guys at iron cross, they get great reviews here
rkidd
Audio Systems
07-01-2016 05:38 AM
tbuxx55
Audio Systems
11
03-22-2015 07:47 PM
HD101st
05-28-2010 07:03 PM
cardboard
01-24-2010 05:52 AM
FFLETCHER
10-11-2009 05:12 PM
Quick Reply: HK Radio and Aftermaket Radio Advice
