PC-V & autotune map switch wiring
Anyway, I would like to mount the switch in one of the empty switch areas on the fairing and I really like how they're set up to light up when activated! Is there any way to wire that switch to still light up when activated while not running power to the map switch wiring? Seems to me like it *should* be possible somehow, but I'm not that great with wiring!
Any ideas or am I trying to do the impossible here? Also, any good recommendations/pros/cons about different oil cooler setups? I live in Oklahoma, so it can get really hot!
Thanks!
I never took enough time to figure out how to get the power to the LED without it running through the PC5.
I originally thought a DIODE.. but there is enough volt and amp that causes interferance and didnt work.
FWIW, you can use the standard ACC switch if you remove the P&A fuse in the fuse box, which on my '07 feeds only that switch. OTOH at least as far back as '09's use it for the lighter and '10> add the heated-grip circuit, so check your wiring diagrams.
I'd be interested in an electrical guru helping out here as well, before I mess up my PCV.
