Need advice on a problem that just came about at 10K. Applying the rear brake the pedal shutters, and so does the bike.(09 ultra). Things that have been checked are the rear pads, rotor, belt tension, and axle for proper tourqe. What I discovered is when your moving and hit the engine kill switch, pull in the clutch there is no shutter when the rear brake is used.
The bike has ABS and when you brake hard you can feel the ABS kick in. If the front brake is used at the say time the shuttering is not as bad! Any ideas before I go to the dealer?
Thanks HiTech
My 2010 RG does the same, spoke with a guy I ride with and his Limited also shutters. There was a thread about this issue.
Buddy of mine had the same problem on his Goldwing ( i know, i know) the valve that sends the pulses, (abs proportioning module) was bad and was changed and VOILA...seen it happen in cars when i worked at Advance auto parts and the aforementioned was replaced...Something to think about...i may be way off and i am not a mechanic (well shadetree) but just an idea...
I'll have to try using the rear brake on my SERG I recently bought to see what it does. All I ever use is the fronts to stop. About all I use the rear for is to hold the bike still at a stop light or when I get the garage door opener out of the right glove box to put the door down when I am leaving my house.
I had the same problem a few weeks ago. I sprayed a ton of brake cleaner on the caliper, pads, and rotor, then made a couple of really hard stops, and it went away.
