Rear Brake adjustment
Old Mar 27, 2011 | 07:25 PM
vtwinhd59's Avatar
vtwinhd59
Default Rear Brake adjustment
I've got a 2010 Street Glide with ABS. Does anyone know if there is an adjustment for the rear brake. I really have to push pretty hard on the pedal to get any good braking power. It's been like that since day one. It really didn't concern me until I rode my uncles 2006 SG with out ABS (I know it's a diff bike and without ABS and all) and his rear brake was really sensative and stopped easily with minimal amount of pressure on the pedal. If there is an adjustment or something somewhere could someone please post pics. If there's not I'm assuming maybe I can try just bleeding the rear brake and see if that makes it better. Also what the average amount of miles there touring bike go in between brake jobs. Just curious. Thanks.
Old Mar 27, 2011 | 07:31 PM
69cj's Avatar
69cj
Can't answer your question but I can tell you I have an 07 RK and the rear will lock up at will if I want to.
Old Mar 27, 2011 | 07:32 PM
RK14SGS's Avatar
RK14SGS
Dont know of any adjustment. I put 18K+ on my original rear pads, and could've gotten another thousand or two...
Old Mar 27, 2011 | 08:32 PM
SteveO's Avatar
SteveO
No adjustment. The ABS has a hard pedal.
Old Mar 27, 2011 | 09:26 PM
2black1s's Avatar
2black1s
Disc brakes have no adjustment. The nature of how a disc brake functions is such that no adjustment is necessary or possible.
If you have a rotor that is warped, or has thickness variations, that can lead to excessive brake pedal/lever travel.
Air in the hydraulic system can lead to a spongy feel.
Other causes for excessive pedal/lever travel/pressure could be contaminated pads or rotors thus reducing the available friction; a mechanical binding of the pedal or lever, or calipers; air, contaminated fluid, or an internal leak, within the hydraulic system.
Old Mar 28, 2011 | 06:27 PM
vtwinhd59's Avatar
vtwinhd59
Wow thanks for the info guys I figured it was just the nature of the beast, being that the bike is ABS.
Old Mar 29, 2011 | 01:43 AM
Beemervet's Avatar
Beemervet
You might be pleased to see that there is a wealth of info in the service manual.
Old Mar 29, 2011 | 02:04 AM
103 sedona orange's Avatar
103 sedona orange
It seems like there are a few guys with problems on here with ABS brakes. I would have the dealer check them out. In the HD Service Manual they list a special tool/digatial tech that is needed when dealing with ABS as far as bleeding them. there can be no air in the system.
mfd#1
Jul 30, 2018 08:56 AM
ajmork76
Oct 13, 2017 09:42 AM
dean123
Jan 3, 2016 12:16 PM
rob0225
Oct 13, 2015 12:32 PM
Flood1234
Apr 4, 2014 11:33 AM
